Problem with Air conditioner mount brackets - Team Camaro Tech
post #1 of 6 (permalink) Old Feb 16th, 11, 11:50 AM Thread Starter
Apprentice
I am in the middle of putting back together frame up restore of 68. I have factory air that I want to keep. its a base model 327 engine.
Ok, now my problem. the front and side mounts for the Airconditioner compressor aren't lining up. They are supposed to line up so that the far right bolt hole ont the front mount is dirrectly infront of the bolt hole on the side mount. then the front compressor bolt goes through both. My front mount is sitting too far back. Anyone else run into this and have a solution.
mfeets is offline
post #2 of 6 (permalink) Old Feb 16th, 11, 02:53 PM
Re: Problem with Airconditioner mount brackets
Mike did you reference the AIM? I don't have one handy at the moment, in the garage but it kind of shows the sequence in the book.... I haven't installed mine yet (engine still being built) so kind of curious of what problem you are running into....
Brandan-
1969 Chevrolet Camaro 396 SS X-66
1967 Chevrolet Camaro RS Convertible
Brandan is offline
post #3 of 6 (permalink) Old Feb 16th, 11, 02:58 PM
How much gap do you have, if slight, a washer or shim, and what water pump do you have?? I need to loosen the bracket to water pump, to do mine, then usually need to reseal the water pump.
john68 is offline
post #4 of 6 (permalink) Old Feb 16th, 11, 06:56 PM
Daryl
1968RallySport's Avatar
Here's a couple of pictures of a '68
ID:	20620   Click image for larger version
1968RallySport is offline
post #5 of 6 (permalink) Old Feb 18th, 11, 02:22 PM Thread Starter
Apprentice
Re: Problem with Air conditioner mount brackets
I think I uploaded a picture. My problem is overlap. the only way I see around it is to use washers on on the waterpump but I know there weren't any before my rebuild.
mfeets is offline
post #6 of 6 (permalink) Old Feb 18th, 11, 03:37 PM
Vintage 68's Avatar
Are you using a '608 water pump casting?
Do you have the Front Support bracket bolted tight?
If so - loosen, and align to the Side support bracket, then install rest of components before tightening it up.
There are no washers/spacers under the front mount at pump.
There is a spacer at the rear bolt position on the Side support.
1968 Convertible
Some trucks
Vintage 68 is offline
