Aluminum radiator and stock shroud - Team Camaro Tech
post #1 of 6 (permalink) Old Feb 28th, 11, 02:45 PM Thread Starter
JcGc's Avatar
I'm looking at buying a aluminum radiator for my 1969 Camaro, but I want to keep the stock fan shroud. Do the radiators come with the stock fan shroud mounting tabs? if not, how do you mount the shroud to the radiator. Thanks in advance!!!!
1969 Camaro
JcGc is offline
post #2 of 6 (permalink) Old Feb 28th, 11, 03:34 PM
Tom P's Avatar
Re: Aluminum radiator and stock shroud
My Griffin does have the tabs for the factory shroud. I know Alumitech will add them at no charge, just ask when ordering.
Another option is the Summit kit that bolts on.
67 new build alum. 406 | 69 RS/SS 496 631 HP / 618 TQ | 73 Z28 Survivor 36k miles | 89 IROC Z 2500 miles | 02 SS 35th Anniv. LE 645 miles |11 SS Berger 550HP (1 of 25) | 14 ZL1 6M Recaros
Tom P is offline
post #3 of 6 (permalink) Old Feb 28th, 11, 03:35 PM
Andrew
Andrew69's Avatar
The radiator from Summit Racing has tabs available from them to mount your shroud to the radiator.
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #4 of 6 (permalink) Old Mar 1st, 11, 06:03 PM Thread Starter
JcGc's Avatar
Thank you for the info. I will look into the mounting tabs when I order the radiator.
1969 Camaro
JcGc is offline
post #5 of 6 (permalink) Old Mar 2nd, 11, 05:02 AM
Check with one of our sponsors, http://entropyrad.com
I just replaced my 23" 4 row core with one of their two row wide tube aluminum radiators.
It was a direct drop in and had the clips , used my stock fan shroud. You might pay a little more but they are better constructed than others made in China. These are made in Chicago, USA.
TC # 349
zdld17 is offline
post #6 of 6 (permalink) Old Mar 2nd, 11, 05:31 PM Thread Starter
JcGc's Avatar
zdld17,
Thanks for the link. Very nice radiators, going to save some money and buy one.
1969 Camaro
JcGc is offline
