fan spacer - Team Camaro Tech
post #1 of 4 (permalink) Old Mar 11th, 11, 07:25 PM Thread Starter
RICK
fan spacer
does a 67 with a 290hp/350 need a fan clutch or just the spacer going for the stock look. have been running a clutch for the past few yrs with a slight temp issue, mostly during the summer months in traffic. thinking about changeing to aluiminum rad to hopefully fix the problem. have a 3row in it now.
rbs67cam is offline
post #2 of 4 (permalink) Old Mar 11th, 11, 09:27 PM
Roger
rogerh's Avatar
Re: fan spacer
My 350 only has the spacer with a 4 blade fan. I don't have AC.
Roger
rogerh is offline
post #3 of 4 (permalink) Old Mar 12th, 11, 04:03 AM
Re: fan spacer
Your stock GM cooling system with a properly operating fan clutch and components will adequately cool your car. Not sure what you mean by the "stock look" Both four blade and clutches were stock. I don't have an aluminum radiator and my car cools just fine. 327/300(approx) http://www.camaros.org/coolingsystems.shtml
Also on CRG: http://www.camaros.org/pdf/corv_cooling2.pdf
Sauron67MM is offline
post #4 of 4 (permalink) Old Mar 12th, 11, 09:19 AM
mike
Re: fan spacer
my 67 always ran hot with stock 327 and rad .changed to a 383 with alum rad it still ran hot...changed the temp gauge and now it cools fine ...hmmm.
67 4spd 383 sport coupe
kamloops67 is offline
