Recommend a Radiator for a BBC - Team Camaro Tech
post #1 of 11 (permalink) Old Mar 14th, 11, 06:07 PM Thread Starter
Need a recommendation for a new radiator? Have a 454 BBC, manual trans, no A/C. I want to keep the stock fan and shroud.
I heard good things about Desert Cooler radiators (US Radiator).
Any thoughts or ideas?? Looking for a good one.
Thanks,
1968 Camaro, 454 BBC 500HP, M21
My Camaro:
JB's68toy is offline
post #2 of 11 (permalink) Old Mar 14th, 11, 06:11 PM
Re: Recommend a Radiator for a BBC
4 core, 23" should do fine IMO
68 Camaro~LSx ~all motor
post #3 of 11 (permalink) Old Mar 14th, 11, 06:16 PM Thread Starter
Thanks Doug, what brand or brands would you suggest?
My Camaro:
post #4 of 11 (permalink) Old Mar 14th, 11, 06:19 PM
I pulled my faithful stock 23" 4 row that worked well for many years but was needing core tube reseal. I went to a direct drop in replacement http://www.entropyrad.com/index.php?...od&productId=9
Worked well for me, little more money but its made in USA. I even used my stock offset fan shroud and fan clutch.
TC # 349
zdld17 is offline
post #5 of 11 (permalink) Old Mar 14th, 11, 06:24 PM Thread Starter
Thanks Don,
I just checked out their website, $379 seems reasonable. I like the fact you can use the stock bbc shroud and fan. I guess it works fine seeing you live in Tx with all the heat in the summer.
I will call them tomorrow.
Thanks again,
My Camaro:
post #6 of 11 (permalink) Old Mar 14th, 11, 06:43 PM
Hear good things about a few, have limited experience with a few...
Not something I go through a lot of
Pretty much any you can afford.
post #7 of 11 (permalink) Old Mar 14th, 11, 07:03 PM
V.J.
vjp819's Avatar
John, I bought the Entropy radiator, and it works great. Be sure to let them know you want to use the stock shroud and they will install the clamp fittings on for you.
vjp819 is offline
post #8 of 11 (permalink) Old Mar 15th, 11, 03:56 AM
X2, They need to be reminded about the clips. Other than that , this thing is a direct drop in or it was for me. I used the driver side factory well nuts to mount as the radiator is allowed some flex, even the stock one calls for this. Makes sense.
TC # 349
zdld17 is offline
post #9 of 11 (permalink) Old Mar 15th, 11, 03:09 PM
Banned
Bethanne
Nashville Beth's Avatar
Well if you want a nice radiator for $212, do what Mr Fred Ficarra did :
https://www.camaros.net/forums/showth...or#post1464946
Nashville Beth is offline
post #10 of 11 (permalink) Old Mar 15th, 11, 06:10 PM
JcGc's Avatar
I just bought a Entropy radiator today. If you email Tony and ask him for the budget radiator it costs $219 shipped. Web site says it will cool 700 hp. Here is a link to the radiator : http://cgi.ebay.com/ebaymotors/ws/eB...m=390247628671
1969 Camaro
JcGc is offline
post #11 of 11 (permalink) Old Mar 24th, 11, 09:54 AM
That's not our Entropy model. That's the low budget model that requires redrilling the holes on the drivers side.
entropyrad is offline
