a/c help - Team Camaro Tech
post #1 of 5 (permalink) Old Mar 21st, 11, 06:47 AM Thread Starter
a/c help
hey guys i installed a a/c kit on my car and i am wondering if anyone sells a kit for a factory type plunger that will increase the idle when the a.c kit is on
1967 Camaro RS
383 Stroker 427HP 457TQ
Tremec TKO-600
Strange Engineering 12-Bolt 4.11 Posi
Coys C-55 18" Wheels
Scott MH is offline
post #2 of 5 (permalink) Old Mar 21st, 11, 08:32 AM
Vintage 68's Avatar
Re: a/c help
Depends on carb
Holley sells them for theirs - http://www.holley.com/46-74.asp
Rochester had a bracket and solenoid.
Brackets are on amazon all the time
Solenoids are available over the counter at a parts store
You'll also need a relay to power it from the compressor clutch circuit.
Do not attempt to run both loads off the one feed ...
Seperate and fuse both.
1968 Convertible
Some trucks
Vintage 68 is offline
post #3 of 5 (permalink) Old Mar 22nd, 11, 06:07 AM Thread Starter
Re: a/c help
awesome thanks!
1967 Camaro RS
Tremec TKO-600
Scott MH is offline
post #4 of 5 (permalink) Old Mar 22nd, 11, 08:14 AM
click's Avatar
Re: a/c help
If you dont worry about 'original' you can get the Qjet solenoid at salvage yard off a 80's vintage carbs. I got mine for $5 and jerry rigged it up, works great This pic was when I had it on the holly Edelbrock setup that previous owner had on the car, I converted to Qjet and cast iron manifold, still works fine.
This is the same solenoid on my Qjet.
click is offline
post #5 of 5 (permalink) Old Mar 22nd, 11, 10:09 AM
prostreet69camaro's Avatar
Re: a/c help
Thats a hell of a bracket you made. But it works..........
prostreet69camaro is offline
