Fan works but stops when slide to heater (68 Factory AC car) - Team Camaro Tech
post #1 of 7 (permalink) Old Apr 10th, 11, 06:30 PM Thread Starter
Pete
Hoping someone can help. My fan works fine on all speed settings but when I slide the top lever over to the "hot" heater setting the fan stops. Basically the blower only blows when the top lever is on the fan position.
Its a 68 with factory AC. I have removed the compressor since it seized up many years ago but otherwise everything is stock. Its also intermittent, it works sometimes when I slide it over but then stops working. But it rarely works lately, any help is appreciated.
Pete
1968 Camaro
2009 Porsche 911 Carrera S
Pete68 is offline
post #2 of 7 (permalink) Old Apr 16th, 11, 09:55 PM
Re: Fan works but stops when slide to heater (68 Factory AC car)
I'd have to look at something, I know the high speed fan pulls power from a different circut. But I would need to research it a bit.
Ron
The
An exercise in interchangeability on a Well optioned 67 SS 350 vert.
Geezer is offline
post #3 of 7 (permalink) Old May 6th, 11, 02:00 PM Thread Starter
Pete
I'm wondering if its this?
http://www.rickscamaros.com/camaro-h...ning-1968.html
Does anyone know what this does? And what are the symptoms when these things fail?
Thanks for any and all help.
Pete
1968 Camaro
Pete68 is offline
post #4 of 7 (permalink) Old May 6th, 11, 11:28 PM
Dale
That switch is on top of the heater case, inside the car.
I thought it switched power to the AC compressor.
I do not understand this
"Basically the blower only blows when the top lever is on the fan position."
68 Dana 302, 68 rs 327 daily driver/family car, 71 rs, track car/ driver, 68 firebird 400, 70 formula 400, 73 type LT, 98 TA, 2 goofy kids and an incredible wife.
dale68z is offline
post #5 of 7 (permalink) Old Jun 1st, 11, 12:28 AM Thread Starter
Pete
The top slider on my AC equipped camaro has 4 positions from left to right:
Far left: OFF
One position to the right: Fan
One position more to the right: Interior (This is AC on with recirculating air)
One position more to the right: Exterior (This is AC ON with outside air)
Sliding all the way to the right is the heater.
The fan only blows when the top slider is lined up with "Fan", thats the first position on the left that is just to the right of OFF. Will not blow in any other position on the slider. You can kinda see the top slider in this pic:
Pete
1968 Camaro
Pete68 is offline
post #6 of 7 (permalink) Old Jun 1st, 11, 04:59 AM
you may want to call Classic Auto Air in Tampa. They might have an answer for you. They rebuilt my evaporator case and explained all the switches and relays.
Brandan-
1969 Chevrolet Camaro 396 SS X-66
1967 Chevrolet Camaro RS Convertible
Brandan is offline
post #7 of 7 (permalink) Old Jun 1st, 11, 07:45 AM
I can't remember if there is 2 or 3 switches on that control but it could be a switch or maybe the heator resistor in the evaporator box is defective.
Ron
The
Geezer is offline
