Overflow tank location - Team Camaro Tech
post #1 of 23 (permalink) Old Apr 25th, 11, 09:43 PM Thread Starter
Nev
Still haven't fitted an overflow tank to mine but I have gotta do it.
I have very little room between the battery and overflow pipe location.
What's the rules on the height of the overflow tank?
Should the top of the tank be close to the height of the radiator cap?
Any ideas on tank types / styles and locations?
Rgds,
Nev
Almost finished (?) 68 Camaro
383 stroker
T350
12 bolt Moser
nev68 is offline
post #2 of 23 (permalink) Old Apr 25th, 11, 10:03 PM
Steps
Re: Overflow tank location
Is this a street car?
If so doesnt have an over flow and doesnt need one realy
Top the tank up...go for a drive, park up somewhere, have a coffee (this lets the latent heat in the block heat /expand the water more) then go home.
The water level has adjusted its self to the correct level, on a daily check once a week...I check my daily once a month..dont need to top up between the annual flush.
Steptoe is offline
post #3 of 23 (permalink) Old Apr 27th, 11, 05:53 PM Thread Starter
Nev
Yep, it's a street car
You don't think it's worth having an overflow / recovery tank?
Rgds,
Nev
383 stroker
T350
12 bolt Moser
nev68 is offline
post #4 of 23 (permalink) Old Apr 27th, 11, 06:10 PM
DjD
DjD's Avatar
Nev - if your cooling system is up to snuff, including a good pressure cap it won't spew on you. What you need to know is you only need to fill the radiator up to about 2" below the filler neck. Too full and it will spew when you shut her down.
...Dennis
DjD is offline
post #5 of 23 (permalink) Old Apr 27th, 11, 09:46 PM Thread Starter
Nev
Thanks.
I must be over filling it as I usually add coolant to just below the neck.
Whenever I get home after a drive it will almost certainly lose some coolant out of the overflow.
If we ever get a drag strip running here again I think I will need some type of overflow tank though.
I imagine this rule applies to all tracks
Rgds,
Nev
383 stroker
T350
12 bolt Moser
nev68 is offline
post #6 of 23 (permalink) Old Apr 27th, 11, 10:20 PM
Steps
An old milk bottle jammed down behind the battery with the overflow tube into the top..does the job keeping the scrutineers happy m8.
Once the raditor has spewed out what is not meant to be in there...thats it.
look carefully on the side of the header tank...ther is a stamp
"Cold"
and one above it
"Hot"
And an explanation of what these mean is in the owner hand book lol
GM think of everything m8....
Steptoe is offline
post #7 of 23 (permalink) Old May 6th, 11, 11:32 PM
Dale
Mine is tucked in between the battery and the right fender. I used an existing hole in the fender to attach it.
You can't see it in the picture, but it is there, in the upper left corner. You can see the mounting bolt.
68 Dana 302, 68 rs 327 daily driver/family car, 71 rs, track car/ driver, 68 firebird 400, 70 formula 400, 73 type LT, 98 TA, 2 goofy kids and an incredible wife.
dale68z is offline
post #8 of 23 (permalink) Old May 7th, 11, 04:48 AM
DT
Donny
DT's Avatar
Originally Posted by nev68 View Post
Thanks.
Our cars never had overflow tanks. If you had an original Harrison radiator you would see on the passenger side tank a "COLD FILL" line. Its probably 3 or 4 inches lower then the neck. I would think this is for expansion of the fluid. Simple solution. Just do not fill to the top of radiator.
DT is offline
post #9 of 23 (permalink) Old May 7th, 11, 04:19 PM
Russ
I run what I'd call a "catch can" vs. an overflow tank. Bought a black plastic cylinder style from Summit Racking and mounted it right to the radiator shroud. I don't have a online pic right now but can snap one if you want just PM me.
Russ (RJ)
The Garlic Capital, Gilroy,CA
(sold June 15,2014) 1968 RS convertible that is not quite stock
rj68RS is offline
post #10 of 23 (permalink) Old May 7th, 11, 06:43 PM
Bill
Send a message via MSN to Orange68SS Send a message via Yahoo to Orange68SS
It was easy to install an overflow tank. I went to Auto Zone and picked one up and installed it on the driver side of the radiator support.
[IMG][/IMG]
68 SS Camaro - 468 BB, Tremec 5 Speed, Wilwood Brakes, Curry 9 inch (370 gear)
Orange68SS is offline
post #11 of 23 (permalink) Old May 8th, 11, 07:20 AM
Jack
Use your windshield squirt bottle. This even works for the track tech inspectors.
67 RS
Royal Plum/Parchment
6.0 LSX 4L80e
06 corvette Z06
machine silver
jackr is offline
post #12 of 23 (permalink) Old May 9th, 11, 10:18 AM
I used the rs windshield washer bottle in the rs location it works fine and passes tech at an nhra track.
Dave69Z is offline
post #13 of 23 (permalink) Old May 10th, 11, 02:04 AM Thread Starter
Nev
I've bought one of these (black) http://www.meziere.com/ps-377-387-we100s.aspx
I think it will blend in (I don't like too much shiny stuff)
I plan to put it on the front side of the radiator support
Rgds,
Nev
383 stroker
T350
12 bolt Moser
nev68 is offline
post #14 of 23 (permalink) Old May 11th, 11, 07:35 AM
Michael
I use the '72 Nova (at least I think it's from '72, it's been awhile) one that piggybacks on the leading edge of the passenger wheelhouse. Looks factory and works great.
mahunt is offline
post #15 of 23 (permalink) Old May 12th, 11, 12:47 AM Thread Starter
Nev
Sounds intersting.
Do you have a photo?
Rgds,
Nev
383 stroker
T350
12 bolt Moser
nev68 is offline
