Aluminum Radiator fluid question - Team Camaro Tech
post #1 of 12 (permalink) Old May 4th, 11, 05:49 PM Thread Starter
Kevin
I just put in a new Ron Davis aluminum radiator and was wondering if there is any differant fluids that belong in the aluminum radiators. I was told regular prestone and distilled water mix. Sound right ? or anything better?
383 with iron heads
69Rook is offline
post #2 of 12 (permalink) Old May 4th, 11, 06:37 PM
Rob
satz28's Avatar
Re: Aluminum Radiator fluid question
383 with iron heads
Also, anybody using anodes?
Rob
Sold 6-1-2014 after owning the car for 18+ years
69 Z-28 X-77 HO * DZ Put away * M20 * 4.10
406 CI * CC XR274R 236/[email protected] 564/570 110 LSA/106 ICL * Brodix IK 200
475 HP, 495# tor
Street Tires, Full Exhaust Sep 07 -12.68 @ 113 MPH * Street Tires, Open Headers Oct 08 - 12.65 @ 116.2 MPH
satz28 is offline
post #3 of 12 (permalink) Old May 4th, 11, 08:20 PM
Steiner
I just use 50/50 distilled water and the SuperTech Extended Life "mixes with any coolant" brand from Wal-Mart. Have used it alone, mixed with a Dex-Cool vehicle, and on a factory filled Mopar vehicle with zero issues.
Anodes can be hit or miss but are cheap and extra insurance. They are meant to be a sacrificial metal instead of the aluminum if you have an issue with electrolysis which is when the coolant carries electricity and causes a charge across the aluminum. Maintaining good grounds to prevent that is the best way to prevent it but an anode can be considered a back up.
'69 Camaro
500hp/538lbft
Steiner is offline
post #4 of 12 (permalink) Old May 4th, 11, 08:53 PM Thread Starter
Kevin
Are "anodes" an additive thats added to the radiator? I do have a warning on the radiator to check for electrolysis.
Should I run a copper ground from the radiator to the frame?
69Rook is offline
post #5 of 12 (permalink) Old May 4th, 11, 09:34 PM
Steiner
If you have electrolysis, grounding the radiator increases the chance for corrosion since the stray voltage in the coolant will try to conduct to ground through the radiator if it's the path of least resistance.
You check for electrolysis by putting a meter lead on the battery negative with the car and all accessories running, and then submerging the other lead in the coolant. The value should be as low as possible, 0.15V AC or DC is considered the action level for aluminum by some standards.
The best things you can do is maintain the electrical system with good grounds and keep your coolant flushed and changed out every couple of years. The grounding issue is obvious and the coolant change helps get rid of it before it starts to turn acidic in which case it the electrolytic properties get stronger and it becomes more conductive.
'69 Camaro
500hp/538lbft
Steiner is offline
post #6 of 12 (permalink) Old May 4th, 11, 10:26 PM
Royce
Distilled water and Hyper Lube http://www.hyperlube.com/c3/Super-Coolant-c8.html is what I have run for years, no issues since making the switch. No rust in the block and no scale or corrosion in the radiator. No need for anti freeze unless you are in a climate that freezing is an issue. The car will cool better as well.
Royce (NO XQSSS) Bradley
camaroman7d is offline
post #7 of 12 (permalink) Old May 4th, 11, 11:46 PM
T-Bone's Avatar
Kevin,
Factory cars have been using aluminum radiators for 30+ years, so just about any good coolant with distilled water should be A-OK. Just for fun, I'm running Dex-cool and distilled water in my '68 with aluminum radiator for the past 10 years with no problems.
I really like Steiner's recommendation to check for voltage potential in your radiator coolant - I am going to do it!
Regards, Steve
T-Bone is offline
post #8 of 12 (permalink) Old May 5th, 11, 02:02 PM Thread Starter
Kevin
thanks all, never thought so much about coolant before. I will go with your suggestions and also do the test. ...
ya gotta love this site.
69Rook is offline
post #9 of 12 (permalink) Old May 5th, 11, 08:36 PM
Andy
I have one in my Ron Davis sure cant hurt and any extra insurance is good insurance for what the radiator costs!
http://www.jegs.com/i/JEGS+Performan...51994/10002/-1
67 R/S convertible Nantucket blue deluxe interior orig.
67 rs-ss coupe 565BB-400turbo streetcar/racer project 1.43 60ft 9.683 140.91
2x67rs/ss is offline
post #10 of 12 (permalink) Old May 6th, 11, 09:32 AM
Terry
When I installed a 200 4R trans, BTO suggested going to an aluminum radiator for better cooling. Bought the alum radiator from SUMMIT. I cliked on their "suggested parts" tab and a zinc anode was recommended.Bought it.It screws into where the petcock is at the base of the radiator. Yes, I am an easy upsell. That was three years ago and there is no galvanic action visible. Knock on wood.
Both optimists and pessimists contribute to society. The optimist invents the automobile, the pessimist seat belts, head rests, disc brakes, and air bags.
IRON MAN is offline
post #11 of 12 (permalink) Old May 6th, 11, 09:35 AM Thread Starter
Kevin
Thanks, just ordered one (now that I know what it is).
Just replace it where the drain plug goes? too easy.
69Rook is offline
post #12 of 12 (permalink) Old May 6th, 11, 06:15 PM
Steiner
Yep, pretty easy. Also remember OEM's have been using plastic end tanks for awhile so many radiators aren't ground paths like ours are. If you've got electrolysis, the heater core and aluminum radiator are going to be the most likely places for it to show up since they're so thin. If your two metals where the current is passing are closer on the galvanic scale it's not much of an issue but aluminum and iron aren't so close.
'69 Camaro
500hp/538lbft
Steiner is offline
