Vintage Air not working - Team Camaro Tech
post #1 of 5 (permalink) Old May 8th, 11, 11:51 AM Thread Starter
Tony
Send a message via AIM to tony -Di
I installed a vintage air system in 2005 in my 67 camaro realy didnt use it till 2007 it run well , last your in june comming back from carslile pa . to conn i did notice that i had wated dripping on my foot after about 3 hours which i didnt look in to . but today i took the camaro out for a Mothers day cruse to the beach and the A/C is blowing hot air i do not see the compressor clutch engaging when i select a/c when i had the system charged they put in the die so i could see if i had any leaks which i had to tighten one hose Bnut since then no problems . this winter i was under the panel doing alot of wireing new stereo ,electric door windows ,electric door locks , so i could have disconnected something . so could someone give me a list of checks to do to make sure i didnt disconect something which is i but its going to be .i even had the fuse box apart and was fixing loose connectors i cant find my install manual for the a/c
thanks
tony
tony -Di is offline
post #2 of 5 (permalink) Old May 8th, 11, 12:43 PM
Bill
Send a message via MSN to Orange68SS Send a message via Yahoo to Orange68SS
Re: Vintage Air not working
If by any chance you discounted power to the unit, then you have to reprogram again.
68 SS Camaro - 468 BB, Tremec 5 Speed, Wilwood Brakes, Curry 9 inch (370 gear)
Orange68SS is offline
post #3 of 5 (permalink) Old May 8th, 11, 01:51 PM
prostreet69camaro's Avatar
I have never heard of having to reprogram it unless you have a electronic thermostat controller like Dakota Digital.
The unit has a circuit breaker which feeds power to the compressor and heater control valve. Make sure you have power to the circuit breaker and relays.
The compressor gets power thru the pressure switch on the accumulator / dryer. Make sure you have power at the pressure switch and thru the other side of the switch. If the pressure is low then the switch will not let 12 volts go to the compressor.
You might not have no power to the unit or low on refrigerant.
prostreet69camaro is offline
post #4 of 5 (permalink) Old May 8th, 11, 04:22 PM Thread Starter
Tony
well thanks for the resposences .i went out and cked or should say started to ck them i just made shure and the thermostate wires where on and its not programable . and it started working . so i didnt see anything obvious but its working so we will see
thanks
tony
tony -Di is offline
post #5 of 5 (permalink) Old May 8th, 11, 05:44 PM
thanks
tony
You musta forgot to turn it on the first time.
