heater core swap (need help) - Team Camaro Tech
post #1 of 2 (permalink) Old May 9th, 11, 08:40 PM Thread Starter
Patric
converting from sb to bb heater core. bought 398223 vista ready air part number but i am unable to attach it properly even with bb clips. all the parts are new except from the heater core box that is from a 69 bird. thank your help will be appreciated. I can add picture if you give the instruction to put them on.
thank you
patvac is offline
post #2 of 2 (permalink) Old May 11th, 11, 06:28 PM Thread Starter
Patric
Re: heater core swap (need help)
It's like if the pipe where not exactly a the right place. The bb clip on pass doesn'T fit in the recess and on the driver side the clip is about 5/8 on an inch lower
When you do a swap, shoud the clips go at the exact same location as sbc or box as to be modified
thank you
patvac is offline
