Fan hits radiator - Team Camaro Tech
post #1 of 20 (permalink) Old May 12th, 11, 06:50 PM Thread Starter
Fan hits radiator
I have a 69 396 that we are putting together from a lot of parts removed by the former owner. We put on a new water pump (trw pump from ricks wk4). I'm using a 4 core 23" us radiator for an automatic trans. The fan hits the radiator. I'm wondering if we have done something wrong or if there is a special water pump that I should have used? Any suggestions? Thanks
scotttritech is offline
post #2 of 20 (permalink) Old May 12th, 11, 06:53 PM
69-Pace's Avatar
Re: Fan hits radiator
Scott,
Take a look here and see if you have the right stuff installed.
http://www.camaros.org/coolingsystems.shtml
Always my first stop when looking up replacement parts.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #3 of 20 (permalink) Old May 12th, 11, 07:15 PM Thread Starter
I definitely have the 1" spacer. The radiator has no end tags on it. It is a new one from ricks that is reported to be the oem size. The water pump is also new and is supposed to be the same as stock. The fan is the 4 blade one. If I would install the fan the other way it gets even closer to the front. The measured difference is about 3 3/4" from the fan to the rad support bracket which is about the same as the radiator.
post #4 of 20 (permalink) Old May 12th, 11, 08:44 PM
69-Pace's Avatar
How many rows in the new radiator core? Does that match what CRG says your engine/options came with?
69-Pace is offline
post #5 of 20 (permalink) Old May 16th, 11, 05:28 PM Thread Starter
The report said that the radiator with an ac optioned car had a 4 core unit which is what I have. I installed what I think are big block engine mounts but I am not certain. Could that be the probable problem? Would that have moved the the engine forward slightly?
post #6 of 20 (permalink) Old May 16th, 11, 05:52 PM
Steiner
What's the measurement from the back side of each head to the firewall? I don't have a big block and don't know myself but someone else can probably post up numbers for comparison. As far as mounts, the correct big block stands only move the engine over to the side and don't affect front/rear as far as I know. It is possible to put 307/327 engine mounts (which are wider) on big block stands but they'd only let you move the engine less than a quarter inch or so plus they'd make the engine sit too low so the pan might hit the crossmember.
'69 Camaro
500hp/538lbft
Steiner is offline
post #7 of 20 (permalink) Old May 16th, 11, 05:53 PM
DT
Donny
DT's Avatar
Post some pics! There should be plenty of room between the radiator and the water pump. You must have the wrong engine stands/mounts ?? Just as a point of reference , I measure approximately 14 inches from the radiator support (drivers side) to the face of the head. I have an original X66 BB car.
DT is offline
post #8 of 20 (permalink) Old May 16th, 11, 06:14 PM
Paul
Fwiw I think I would use the long water pump,'772' fan, seven blade fan with a fan clutch, and not use the spacer
Chevonly is offline
post #9 of 20 (permalink) Old May 16th, 11, 06:27 PM Thread Starter
Looks like about 12 1/2" on the driver side. Not sure why so much less
post #10 of 20 (permalink) Old May 16th, 11, 06:30 PM Thread Starter
Measurement from pass side from head to fire wall is about 3 3/4".
post #11 of 20 (permalink) Old May 16th, 11, 06:33 PM
Steiner
Sounds like wrong frame stands or bolted to the wrong spot.
'69 Camaro
500hp/538lbft
Steiner is offline
post #12 of 20 (permalink) Old May 16th, 11, 06:53 PM Thread Starter
There are only three holes thAt lined up so not surenhow I would have bolted to the wrong holes. But the stands are possibly wrong. How can I check them. Is there a front and back to engine mounts is it possible to mount them backwards?
post #13 of 20 (permalink) Old May 16th, 11, 07:15 PM
Steiner
All you ever wanted to know about stands and mounts:
http://www.pozziracing.com/camaro_engine.htm
They should hang off the back of the crossmember but I don't think it's possible to bolt them to the wrong sides although that would cause the engine to shift forward, plus with big block stands it would really sit crooked if it were possible.
If they are the correct big block stands, the carb stud should be sitting an inch or so shifted over to the passenger side, not centered with the bead on the cowl/header panels.
'69 Camaro
500hp/538lbft
Steiner is offline
post #14 of 20 (permalink) Old May 16th, 11, 11:34 PM
Fred
Hang on, I'll go pull my engine. Be right back,,,,,,
Whew, hope these help. (original, never been touched)
Also on Davids web site, the BB engine mount is not the same as mine. And mine's original. Mine has a large engine-side stamping that encompasses the entire frame mount. A large bolt with a bushing passes through it. The bolt will hit the stamping if the rubber fails. Classic Camaro shows it on their web site. I'll try and find it.
Nope, horrible web site! The search engine sucks.
Remind me to crawl under there in the morning to take a picture,,,,,,
128.79mph 1.428 60'
Fred Ficarra is offline
post #15 of 20 (permalink) Old May 16th, 11, 11:45 PM
Holy cow! There shouldn't be that much space there, although I don't know what the correct space is. Sounds like you've got the frame stands in the wrong spot.
buenymayor is online now
