Heater hose help with tall vanlve covers - Team Camaro Tech
post #1 of 21 (permalink) Old May 15th, 11, 05:09 PM Thread Starter
Keith
I just had to replace the heater cor ein my '67 (not fun).
As you cans see in the photo below, I have a problem (was the same way with the core I just replaced)--The upper hose sits right up against the valve cover, to a point where I am concerned that coolant flow is being restricted.
I have new valve covers (GM performance parts slant covers) that I want to use, bu they make the problem worse when test-fitting.
Is there any way around this issue, or a hose fitting that I can utilize to make this work without restricting flow?
Does anyone else have tall valve covers and is having/fixed this issue?
Thanks!
Keith
1967 Camaro
Muncie M-20
GM 8.5, 3.73 posi
keithl1967 is offline
post #2 of 21 (permalink) Old May 15th, 11, 05:29 PM
Re: Heater hose help with tall vanlve covers
That heater core looks like it doesn't have the correct bends in the outlet tubes. With that hose hitting the VC I'd think eventually it will crack the tube to core solder joint.
I know this advice is late - but I'd do the swap to a BB style heater core.
BPOS is offline
post #3 of 21 (permalink) Old May 15th, 11, 06:00 PM Thread Starter
Keith
what's entailed in the BB swap?
I just got it back from the body shop 2 days ago, completely redone exterior and paint, so I am not keen on removing the fender to put a new box under the hood...
Keith
1967 Camaro
Muncie M-20
GM 8.5, 3.73 posi
post #4 of 21 (permalink) Old May 15th, 11, 09:10 PM
It's pretty easy. You don't need to remove the fender or the underhood box. You need a BB heater core and the tube flange plate (Rick's p/n hc-12). Use the flange plate as a template for the new holes. I wish I'da done it a few years back but I wasn't thinking.....
BPOS is offline
post #5 of 21 (permalink) Old May 16th, 11, 04:47 AM Thread Starter
Keith
How do I know where to drill the holes (to make sure I get them in the correct place)?
Keith
1967 Camaro
Muncie M-20
GM 8.5, 3.73 posi
post #6 of 21 (permalink) Old May 16th, 11, 06:12 AM
DT
Donny
DT's Avatar
Keith, why are you running Tall valve covers?? What rockers are you using?? If you switch to Comp Cams magnum roller rocker arms they fit under the stock valve cover. Just a thought.
DT is offline
post #7 of 21 (permalink) Old May 16th, 11, 01:20 PM
Matt
Here is how I made mine work using house couplers. BBC heater core is the correct way of fixing it for sure. As mentioned already looks like the tube bends are not correct or someone cutoff the end of the tubes that were bent correctly at one point in time.
Matt
zlek131 is offline
post #8 of 21 (permalink) Old May 16th, 11, 03:36 PM Thread Starter
Keith
Bottom bends toward the passenger fender, but the top is "straight" through...I believe that is correct. I'll have to look into the BB core to fix the problem... I may try a 90 dgree hose first, though...mabe cut the upper tube a little bit shorter to clear the cover...
Keith
1967 Camaro
Muncie M-20
GM 8.5, 3.73 posi
post #9 of 21 (permalink) Old May 17th, 11, 04:24 PM Thread Starter
Keith
Do you know what part number/where you got that heater core in your car...none that I have found have that bend in the top pipe?
Keith
1967 Camaro
Muncie M-20
GM 8.5, 3.73 posi
post #10 of 21 (permalink) Old May 17th, 11, 06:53 PM
Matt
Sorry, no part #, 99% sure that core is original. Mine was a 6 cyl car, perhaps that makes a difference.
Matt
zlek131 is offline
post #11 of 21 (permalink) Old May 17th, 11, 09:29 PM
JAY
Greetings from Arizona
On my 67 Elcamino with tall valve covers on 327 motor, I bought Dayco heater hoses with 90 degree end already molded in hose, I cut 90 degree end as short as needed and used other hose with 90 on engine side so I have no splices in hose at all. don't know if this shows on on my photobucket or not. Jay
PS: On Photobucket 1st page, pictures #9 and #11 are engine pictures of MS ELLIE and you can see heater hose to engine connection. also check out my vacumn, wiring and pcv hoses. All done with metal brake lines and small hoses j
66 SS Chevyll
67 Elcamino
68 Malibu 2dr
69 Camaro Convertible
JAYARTER is offline
post #12 of 21 (permalink) Old May 18th, 11, 04:51 AM Thread Starter
Keith
Jay--I checked out your photos--the issue I am having is at the firewall, where the hose connects to the heater core, not at the engine side.
I picked up a 90 degree bend last night, but I suspect that it is not going to be sufficient at the firewall
Keith
1967 Camaro
Muncie M-20
GM 8.5, 3.73 posi
post #13 of 21 (permalink) Old May 18th, 11, 04:52 AM Thread Starter
Keith
Mine, too was a 6 cylinder in its early life! The heater core has been replced (this was now the second time in its life), but each time the core has matched the previous one installed...
I wonder if there is a core for another vehicle that will fit with the bends that I need?
Keith
1967 Camaro
Muncie M-20
GM 8.5, 3.73 posi
post #14 of 21 (permalink) Old May 18th, 11, 08:14 AM
Matt
I wonder of my tube was simply rebent just to make it work/fit....? I'll look through some other pics to see if I have a shot of the tubes with no hoses on them.
Matt
zlek131 is offline
post #15 of 21 (permalink) Old May 18th, 11, 05:52 PM Thread Starter
Keith
Thanks...I assume this is why my car often runs hot (not overheats), just hot...maybe some restricted coolant flow...
Keith
1967 Camaro
Muncie M-20
GM 8.5, 3.73 posi
