Mixing anti-freeze - Team Camaro Tech
post #1 of 13 (permalink) Old May 24th, 11, 11:08 PM Thread Starter
Jerod
Mixing anti-freeze
I am getting ready to fill up my new radiator for my new motor in my 1969 Camaro. I do not drive it in the winter. What ratio should I mix it at. I am in IA so it does freeze in the winter. Thanks, Jerod
mjlynch71 is offline
post #2 of 13 (permalink) Old May 25th, 11, 12:08 AM
Re: Mixing anti-freeze
50/50 with distilled water.
buenymayor is offline
post #3 of 13 (permalink) Old May 25th, 11, 04:57 AM
George
Just be sure you didn't purchase pre-mixed coolant, as you would not want to dilute it. Just mentioning, as there is a lot of the pre-mixed in the market place, which gets used with no water added. The packaging usually spells this out, but can be missed, as we often don't read the "instructions" - I think it's a guy thing. LOL
67 RS Ragtop is offline
post #4 of 13 (permalink) Old May 25th, 11, 03:32 PM
Steps
This depends on the condition of your local tap water...if good fine if not it may deteriate the anti corrosion properties quicker.
Also..lets face it who tops up the radiator with distlled....
There are several types of antfreeze...these types are marketed in different parts ot the world and contenents due to different water properties..
Make sure u have the right sort for your local conditions
very good point, see that down the workshop a few times....when checking coolant and find is way to dilute....
That makes no difference....If u have low temps, u still dont want water freezing....
If warm winters 20 to 30% coolant
If cold 40 to 50%
BUT..one of the very important properties of antifreeze is anti corrosision, and preventing electoliyis between the different alloys and metals in the engine...
So at the end of the day 40 to 50% regardless.
Steptoe is offline
post #5 of 13 (permalink) Old May 25th, 11, 05:05 PM
Dan
One thing to remember, it is anti-freeze and coolant. It works both ways. In my 34 in the shop we always mix 50/50. Thats my story and I am sticking to it.
MasterTech
Dan.
MasterTech is offline
post #6 of 13 (permalink) Old May 25th, 11, 07:04 PM
Steps
exactly...
Steptoe is offline
post #7 of 13 (permalink) Old May 25th, 11, 09:02 PM
I do. It's darned near free at Wally World, and after pulling the sleeves out of one of my diesels, I'm never putting tap water in radiator again.
post #8 of 13 (permalink) Old May 26th, 11, 03:39 PM
Steps
We are fortunate in NZ.....bloody good resovour tap water, if on bore water, dont even consider using it.
If in a area that a dripping tap will stain a bath, or the jug gets a build up, or the hot water cylinders get crap before before falling apart after 50yrs, or the swimming or spa poll requires whater hardness adjusting when refilling....
Use Distilled water......and in the battery also.
Steptoe is offline
post #9 of 13 (permalink) Old May 27th, 11, 05:01 PM
RSS
Rick
X2, it's all I use in all my vehicles.
It takes a fool or an idiot to first criticize! It takes a wise and intelligent man to first ask why!
1969 coupe under going restification (Almost Done!)
RSS is offline
post #10 of 13 (permalink) Old Jun 1st, 11, 07:42 AM
Antifreeze/Coolant is designed to work best in the 50/50 mix range.
It provides the highest temp from boil over and lowest from freezing.
The chart is on the jug.
71 Camaro 355 NA
11.1650 @ 119.30
1.5028 60'
hhott71 is offline
post #11 of 13 (permalink) Old Jun 1st, 11, 09:33 AM
Brandon
X3, Lake Mead water is nasty as hell, Good Striper fishing though (well at least before they dropped the level down so low).
Brandon J. licence 1NASTY67
Nantooch is offline
post #12 of 13 (permalink) Old Jun 1st, 11, 10:35 AM
RSS
Rick
Nasty is an understatement, but they ARE finally raising the lake level 20 to 30 feet over the course of the summer.
RSS is offline
post #13 of 13 (permalink) Old Jun 1st, 11, 11:26 AM
Brandon
Rick,
Nice to hear that. It was so sad that it was dropped after 9/11 almost over night and bs was given as the reason. Places I used to fish at that were 450' deep were only like 280' when I moved.
Nantooch is offline
