What temp sensor unit to use? - Team Camaro Tech
post #1 of 5 (permalink) Old Jun 15th, 11, 02:07 PM Thread Starter
Ken
I had a set of Autometer gauges with an electric temp sensor unit in my 350. The gauge registers 100 to 250 degrees on the face. We're installing a console with factory type gauges that I bought from someone and we can't find a sensor unit with the kit. Will that Autometer sensor work? My restorer thought there might be difference in sensors for idiot lights vs gauges.
Winch is offline
post #2 of 5 (permalink) Old Jun 15th, 11, 05:16 PM
Re: What temp sensor unit to use?
Idiot lights use a thermal switch.
Gauges uses a temperature sensor, the hotter the coolant gets, the lower the resistance, the more the gauge indicates - negative temperature coefficient is the name.
If Autometer gauge and an Autometer sensor with the right coefficient, dunk it into a pan of water with a known thermometer and hook up power to the gauge and sensor and see what the gauge indicates.
post #3 of 5 (permalink) Old Jun 15th, 11, 09:31 PM
69-Pace's Avatar
If it doesn't calibrate right sender units are available from
Ricks http://www.rickscamaros.com/camaro-c...uges-1969.html,
Classic https://www.classicindustries.com/ca...rts/g1852.html
and Lectric Limited http://www.lectriclimited.com/images...%20senders.jpg http://www.lectriclimited.com/mainpage.htm
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #4 of 5 (permalink) Old Jun 16th, 11, 04:11 AM Thread Starter
Ken
The restorer picked up a new one for stock gauges at AZ. He thought the one that was in it was for the idiot light. We'll see how it works. Should be OK.
Winch is offline
post #5 of 5 (permalink) Old Jul 10th, 11, 06:34 AM Thread Starter
Ken
Well we never got to see if the Autometer sending unit would work with the factory repop gauges. He put a new unit in the drivers side for the factory gauges and it still didn't work. Turns out the gauge wasn't grounded. Works fine with the factory combination now. I still have the Autometer unit in the passenger side. I mihgt hook up the Autometer just for grins some time to compare the reading of both gauges.
Winch is offline
