V/A in ls1 swap - Team Camaro Tech
post #1 of 7 (permalink) Old Jun 28th, 11, 09:35 AM Thread Starter
Louis
V/A in ls1 swap
i have a 1967 camaro non factory ac and want to get the vintage air.
i put an ls1 in it and want to know what i can salvage from my ls1 i have everything from the 2002 ws6 camaro ac unit what can i use from that with the vintage air
thanks
louis
RaiderNation67 is offline
post #2 of 7 (permalink) Old Jun 28th, 11, 03:19 PM
Re: V/A in ls1 swap
Nothing, really. The VA kit is complete. Even has a bracket to mount the compressor in stock LS1 location. You will likely have to notch the crossmember if you decide to mount it there. LS1 compressor not compatible with VA unit.
69 RS LS3/T56
68 Firebird vert LS1/4L60E
67 RS LS2/T56
Z06vette is offline
post #3 of 7 (permalink) Old Jun 28th, 11, 05:26 PM Thread Starter
Louis
Re: V/A in ls1 swap
how many mpg do you get on your 1967 camaro ls1 t56 im getting 17mpg highway before the tune still havent calculated it. back to the vintage air they do have a bracket to relocate the compressor to the top for people that wants to relocate the alternator
post #4 of 7 (permalink) Old Jun 28th, 11, 05:33 PM
Re: V/A in ls1 swap
KWIK sells a bracket that moves the compressor up on high on the Pass side. Thats what I'm running. My 67 had the LS1/auto- it got about 24 mpg on the highway w/3.42's. My 69 has a cam & 3.73's. On way home from powertour this year I got 26mpg from nashville to pensacola, fl., running 75-80mph. Here's a pic of the KWIK bracket on my 69 with Fbody acc.
69 RS LS3/T56
67 RS LS2/T56
Z06vette is offline
post #5 of 7 (permalink) Old Jun 29th, 11, 11:32 AM Thread Starter
Louis
Re: V/A in ls1 swap
very nice. all of that if from vintage air for the ac setup minus the bracket right? also your 69 everything was tuned right cause right now i have 3.73 and before the tune i got literally like 12 mpg highway and city together and one time nearly 17 mpg on the highway my motor is stock with the slp mafs and ls6 intake and sanderson headers, also before the tune my was running super leaning making it run too hot and they adjusted it, it seems to run a lot smoother ac cell a lot better and sound a lot better i just havent been able to run the car cause i been soo busy with school
thanks
louis
post #6 of 7 (permalink) Old Jun 29th, 11, 11:33 AM Thread Starter
Louis
Re: V/A in ls1 swap
i was thinking of also putting that fat cat dyna mat its cheaper then dynamat how do you like it
post #7 of 7 (permalink) Old Jun 29th, 11, 12:37 PM
Re: V/A in ls1 swap
Ya I had it dyno'd and tuned with wideband. I was happy with the fatmat. I prefer working with the large sheets rather than the big roll. It was just easier to work with. You may be able to buy the VA kit along with the KWIK bracket- just depends on which vendor you use.
69 RS LS3/T56
67 RS LS2/T56
Z06vette is offline
