Where can I buy Hardline for Vintage Air? - Team Camaro Tech
post #1 of 4 (permalink) Old Jul 9th, 11, 10:17 AM Thread Starter
Tony
Does anyone know who can make a hardline for my Vintage Air heater hose line? Basically I need the same bents in the hardline, but need it 4in longer where the yellow caps are?
Thanks,
Tony
tonyvol is offline
post #2 of 4 (permalink) Old Jul 9th, 11, 10:38 AM
Terry
Re: Where can I buy Hardline for Vintage Air?
Tony, Did you ask Vintage Air if they could make them?
Also, where are you located? If you are near San Francisco, Ca, there is a business named the Source Tube & Hose in Contra Costa County . Joe the owner/tech makes hoses and lines for hydraulic and A/C. He fabricated the hoses for my 68 Camaro with Classic Auto Air. The lines run between the fender and above the wheel house sheetmetal ...more out of sight. Joe is making a high pressure ps hose for a kit car I'm restoring. I gave him photos and a drawing, and the old hose to go by even though the metal tube part is being extended 5" and the bends will be different. His ph # 925-682-5200.
Both optimists and pessimists contribute to society. The optimist invents the automobile, the pessimist seat belts, head rests, disc brakes, and air bags.
IRON MAN is offline
post #3 of 4 (permalink) Old Jul 9th, 11, 01:52 PM
dan
sixd8rs's Avatar
You could take those aluminum pieces off and make your own using braided line and A.N. fittings for a/c. If I remember correctly, I still have those pieces in a box and didnt use them. I ran my braided line right to the brass fittings.
68 RS
sixd8rs is offline
post #4 of 4 (permalink) Old Jul 9th, 11, 01:57 PM
Greg
Just as another idea, I used short heater barbs and ran the regular hose thru the blower hole, but in a DSE block off plate first.
1969 RS/SS Vert
1031 Engineering llc
chops is offline
