BBC 4 Core Radiator Mounting - Team Camaro Tech
post #1 of 12 (permalink) Old Jul 14th, 11, 10:09 AM Thread Starter
Question BBC 4 Core Radiator Mounting
Got a question about how the radiator is mounted. My 67 car has an NOS radiator support with a repop 4 core radiator. When I put the radiator in using the factory holes on the right side, the right side tank sits on top of the rounded edge of the support opening. This causes a large gap when trying to pull that side up tight to the support. I have the AIM and I'm pretty sure I'm using the correct bolt holes on the support.
I don't think I can move it any closer to the fender because of the battery tray.
Is this the way it is supposed to be? If I'm doing something wrong, please give me some advice.
TIA
67 3L 4P Project Car
I just had to have some wings.
67 RS/SS Pictures
cpodeep is offline
post #2 of 12 (permalink) Old Jul 14th, 11, 12:26 PM
Re: BBC 4 Core Radiator Mounting
The right side mounting is pretty constant on a factory mounting. Its the left side that you have two mounting positions due to the use of sbc or bbc length radiators.
For a long period , I used the 23"bbc style radiator and it pretty much took up all open spaces on the left side. Right side was as you say, tank was close to then battery tray.
For the sake of body panel movements within the frame, be sure to use the rubber insulated well nuts on the left side.
TC # 349
zdld17 is offline
post #3 of 12 (permalink) Old Jul 15th, 11, 03:05 AM Thread Starter
Yes....it is real tight on the right side....there is no room to move anything. I will try to get some pics over the weekend.
67 RS/SS Pictures
cpodeep is offline
post #4 of 12 (permalink) Old Jul 15th, 11, 08:40 AM
Bob
Will your radiator fit the opening using just the left side mounts?
Big Iron is offline
post #5 of 12 (permalink) Old Jul 17th, 11, 03:35 AM Thread Starter
Ok....took some pictures yesterday.
In picture 1 you can see that I have the bottom bolt through the radiator flange and into them correct hole in the radiator support. The hole in the radiator is slotted and I have pushed the radiator as far as the slot will let me to the right. Also in the picture you can see that the battery tray is against the side of the radiator, so the radiator can't move any further to the right.
In picture 2 this is a top view looking down and you can see that the flange for the radiator tank is not moved far enough to the right to clear the rad suppot opening. This causes the radiator to stick way out at the top.
In picture 3...this is the bolting on the left side. The top open hole is the correct hole to be used with the rubber insolating bolts. I can't move the radiator to the right to get these bolts in....so I stuck a bolt in one of the other bolt holes just to hold it on.
I'm at a total lose as to where to start trying to move things to make this work and look corrrect. I really don't want to start jury rigging things now.
If anyone has had this problem and can offer some advice...I would really appreciate it.
ID:	23500   Click image for larger version
ID:	23501   Click image for larger version
67 RS/SS Pictures
cpodeep is offline
post #6 of 12 (permalink) Old Jul 17th, 11, 05:27 AM
mark
mark x22's Avatar
In picture 2 my radiator has about .09 clearance . Your tank brackets are located wrong you need to send it back or have them moved . Original brackets are formed to fit the tank not flat .
mark x22 is offline
post #7 of 12 (permalink) Old Jul 17th, 11, 08:25 AM
Bob
2x
Big Iron is offline
post #8 of 12 (permalink) Old Jul 17th, 11, 09:44 AM Thread Starter
Thanks guys!
Sending it back is not an option....I bought it up at Carlisle about 3 years ago....its been sitting in a box all this time.
I wonder if I could find some OEM type brackets and have a radiator shop here in town change them out? If so....anyone got any idea where I could find them?
67 RS/SS Pictures
cpodeep is offline
post #9 of 12 (permalink) Old Jul 17th, 11, 09:56 AM
mark
mark x22's Avatar
http://www.rickscamaros.com/camaro-r...1967-1969.html I don't know if this will fit your tanks , you will have to ask . Or you might have a local shop move them .
mark x22 is offline
post #10 of 12 (permalink) Old Jul 18th, 11, 04:31 AM Thread Starter
Thanks Mark!
Boy...they must be pretty proud of those brackets! $$$$
I'm not sure what you mean by having a shop move the existing brackets....I don't think there is anywhere to go with them?
67 RS/SS Pictures
cpodeep is offline
post #11 of 12 (permalink) Old Jul 18th, 11, 02:43 PM
mark
mark x22's Avatar
They are soldered on can they be removed from the tanks and moved forward ?
mark x22 is offline
post #12 of 12 (permalink) Old Jul 19th, 11, 03:51 AM Thread Starter
Mark!
Ok...I got you now. I will have to go to the garage this afternoon and see if there is any room between the mounting bracket and the tank.....if so....just have a shop move the bracket against the tank and it might just work.
I did see that HBC has the replacement brackets for $119. a little cheaper
67 RS/SS Pictures
cpodeep is offline
