Gasket or not? - Team Camaro Tech
post #1 of 8 (permalink) Old Jul 15th, 11, 06:28 AM Thread Starter
Jan
Gasket or not?
Was there any gasket between the blower motor and the box or did they use a seam sealant?
67 Swedish Convertible
67 Swedish Convertible is offline
post #2 of 8 (permalink) Old Jul 15th, 11, 08:13 AM
Bob
Re: Gasket or not?
Look in 67 AIM 1 A6 view A. # 9985059 pumpable black sealer.
Big Iron is offline
post #3 of 8 (permalink) Old Jul 16th, 11, 05:49 AM Thread Starter
Jan
Re: Gasket or not?
Thanks BigIron,
But I beg to differ..There is nothing, as far as I understand, on 1A6 that says that there should be sealant between the electrical motor and the box. I can agree that there hould be .03 gallon of sealing compound between the box and the firewall- but not the motor. The number (9985059) you mention is nowhere to be found on that page.
Am I reading it wrong?
Thanks again
post #4 of 8 (permalink) Old Jul 17th, 11, 08:19 AM
Bob
Re: Gasket or not?
Mis-read your post, the sealer I mentioned is for the case to the firewall. Never seen an original with a gasket or sealer between motor and case.
Go to AIM 0 D5 to find numbers for sealers.
Sorry for the confusion.
Bob
Big Iron is offline
post #5 of 8 (permalink) Old Jul 18th, 11, 02:16 AM Thread Starter
Jan
Re: Gasket or not?
Thanks Bob,
Would it hurt to put a tiny bit of sealant between the motor and the case? Just to keep dust and vapors out..? Will check the page you suggested.
Thnk again
Jan
post #6 of 8 (permalink) Old Jul 18th, 11, 05:25 AM
Jeff
yellow69RS's Avatar
Re: Gasket or not?
I've always seen blower motors installed with a bead of strip caulk around them. I can't recall working on anything as old a first gen to be sure they used it on them but seems everything else I've worked on had it.
Jeff
yellow69RS is offline
post #7 of 8 (permalink) Old Jul 18th, 11, 12:14 PM
Bob
Re: Gasket or not?
Why not, anything you can do to help the case from leaking will only help first gen. heating and air.
Big Iron is offline
post #8 of 8 (permalink) Old Jul 20th, 11, 10:36 AM Thread Starter
Jan
Re: Gasket or not?
Thanks for your input guys!
