Do I have a overheating problem? - Team Camaro Tech
post #1 of 13 (permalink) Old Jul 19th, 11, 04:46 PM Thread Starter
Tad
I had my 396 out today in 100 degree heat. I drove 15 miles on the hiway. Then stopped at the mech to use his infared temp gun. With factory console temp gauge on 3/4 to red line. The temp gun said 215 when pointing at the thermostat housing. After lating her idle with vintage air on coolant started to drip out of overflow hose. when I shut it off i would say 20 oz came out of over flow. On the way home with ac on (which isn't very cool and the clutch kicks on and off nearly every three to four seconds) the temp gauge showed just a little past 1/2.
Can I go by the temp gun readings ? Are those guns acurate?
I would like to add another temp gauage. Has anyone ran two temp gauges? If so where do you put the other temp sender.
Could my current temp sender be the issue? Does anyone have the part number to the correct one?
Thanks in advance.
Tad Frahm is offline
post #2 of 13 (permalink) Old Jul 19th, 11, 06:04 PM
DT
Donny
DT's Avatar
Re: Do I have a overheating problem?
Sounds like you need freon if the compressor is kicking off and on. Anyway 215 for a Big Block is not exactly running hot. These cars do not have overflow tanks. If you filled up the radiator too much, it will spew out like that when you shut it down.
DT is offline
post #3 of 13 (permalink) Old Jul 20th, 11, 01:01 AM
Bryon
bcm66's Avatar
I think you need to tell us a bit more information. 396 in what car? Stock engine? You didn't say and there is nothing in your information. Do you have an original big block radiator? Aluminum aftermarket radiator? Are you running a shroud? What thermostat?
Big blocks tend to run a bit hotter, especially when it is close to 100 degrees. But I have never had mine push anything out the overflow.
AC system probably does need freon. That is mostly likely why the ac is "not very cool".
68 Camaro SS 396 - 468 BBC now, M21, 12 bolt 3.73 coded housing but w/ 3.31 gears.
Looking for 68 Camaro with body number NOR 181016
CRG -
bcm66 is offline
post #4 of 13 (permalink) Old Jul 20th, 11, 04:13 AM
As said, BBC's run hotter, especially with A/C on.
Need more freon. Adding more freon will increase condensor pressure and temperature of air pulled across condensor. Seven blade fan and fan clutch? Place a box fan in front of car when adding freon.
Yes, coolant will come out the overflow. Might add a reservior to catch the coolant and allow it to be sucked back in after it cools.
Might need to add a 18-22 lb cap to prevent boiling.
Check Owner's Manual, it reads a 195F thermostat is used.
You can run a second gauge in the other cyl head.
You might isolate the grille and valance with homemade panles to prevent recirculation of heated air across the condensor/radiator. The foam gaskets are installed as the factory did on the rad support and in between the fenders behind the headlamp buckets?
Everett#2390 is online now
post #5 of 13 (permalink) Old Jul 20th, 11, 04:28 AM
Steps
Even with a BB the stock cooling sysyem is way over built..For normal cruising ands the cores ok, shroud, clutch fan, radiator cap good, bottom hose sprinfg ok....the engine will never get anymore than a few degrees over the rating of the thermostat.
If bit lean or over advanced the system is so effevient again it will not show.
But if leans way out, say tuned for sea level and head up into the snow line it will get up around 210...which is fine..just gets sluggish.
Since it gets over warm at cruise, assuming all else is ok, indicates some blocked cores or restriction thru the front because above about 35/40 mph the air flow thru exceeds anything the fans can put thru.
A crook thermostat or faulty cap, soft bottom hose will cause the same...easy stuff 1st.
Steptoe is offline
post #6 of 13 (permalink) Old Jul 24th, 11, 10:01 PM Thread Starter
Tad
I put in a new aluminum radiator over the weekend. I have driven it during the hottestest part of the day, just a little tonight say 75- 80 degrees. I left it idle with ac on. After a few minutes it did get into the red. I checked my thermostat in a pan of water it started to open at 180 degrees. I do have water in now since the radiator change. But don't think that is a big deal.
Could i have the incorrect sender for the temp gauage?
If it truely is getting hot at idle or slows speeds. What needs to be checked as far as timing, air fuel mixture and vacum advance? These are all things I know nothing about.
Tad
post #7 of 13 (permalink) Old Jul 24th, 11, 10:32 PM
Steps
Or just dont know where the needle is in relation to temp on the gauge
Check along the same lines as u did with the termostat....electic jug, hang the sensor in the jug and a clamp on the body of the sensor for a ground to the car body...a thermoeter also in the jug.
With a stock factory set up these will not effect your temps to any great degree thu tuning at sea level and then heading above snow line will.
All that above is covered in great detail in many posts over and over....use the seach function above and start reading to understand what these are and how they work.
u so have the shroud, the fan set about 1/2 in the shroud?
NEED a shroud.
Steptoe is offline
post #8 of 13 (permalink) Old Jul 24th, 11, 10:44 PM Thread Starter
Tad
Yes I have a shroud. In order to check my temp sender it needs to be grounded ? Is that correct? I can't unscrew it and place in hot water ?
I also hear people talk about speeding up the water pump with a 5.25 0r 5.75 what ever it is water pump pulley. What are your thoughts on this?
I did find a vac advance can as suggested on this forum, the one that is all in at 8. Im not sure how to install. Can you tell me how to install or is it worth it?
post #9 of 13 (permalink) Old Jul 25th, 11, 04:02 AM
You can check the sending unit by dunking it into a pan of water and measure the resistance between the stud/spade and the body - higher temperature, less ohms.
I believe for the gauge to indicate straight up 210F, the s/unit should be around 180-200 ohms across it.
You can measure the resistance of the s/unit with it in the engine by doing the same, disconnect the wire and measure. Also, measure the body to engine block ensuring a good path.
Having a smaller w/pump pulley than the crankshaft pulley will speed up the fan/w/pump.
Or vice versa, get a larger crankshaft pulley than the w/pump pulley and have the w/pump spin faster. Either way is good - smaller w/pump pulley or larger crankshaft pulley. You'll need a different belt either route you chose.
post #10 of 13 (permalink) Old Jul 25th, 11, 05:47 AM Thread Starter
Tad
Where do I find a smaller water pump pulley?
post #11 of 13 (permalink) Old Jul 25th, 11, 07:13 AM
Any aftermarket supplier or simuliar model in the salvage yard, garage sales, swap meets.
It may be easier to find a larger crankshaft pulley.
A start:
http://www.rickscamaros.com/camaro-h...1969-1975.html
post #12 of 13 (permalink) Old Jul 25th, 11, 03:17 PM
DT
Donny
DT's Avatar
What fan are you using??
DT is offline
post #13 of 13 (permalink) Old Jul 25th, 11, 05:09 PM
Steps
As Evertts suggestion above , but that doesnt ID the position of temps on the gauge.
unscrew the sender...leave the 'power' lead on it....usae a wire..one end connected to the -ve battery or a good ground on the car and the other clamped to the sender body around the threads....keep the 'power end out of the water in thejug
Hang a thermoeter in the water...
Now turn the jug on...
When thermoter reaches the 1st mark on the temp gauge in the car ..note the temp in the jug, then the next mark and next mark etc.
I dont think yout issue is the rate of water thru the rasitor...pumed by the water pump...stock speed the water goes thru the raditator so fasty it doesnt cool well, which is why one has the restriuction of the thermostat in the engine...slow it down
If u want to try the effect of higher flow, just remove the thermostat and see what happens.
Steptoe is offline
