New radiator and mounting - Team Camaro Tech
post #1 of 7 (permalink) Old Jul 23rd, 11, 09:16 AM Thread Starter
Kraig
I posted earlier about some overheating issues and I think I have put that to bed. I decided to go with a new radiator from alumitech but upgraded to the larger radiator. I had the SB with trans cooler w/out AC. I jumped up 2 inches in length and bought the SB with trans cooler w/AC aka BB rad. It fits fine but with the 2 extra inches of length it mounts to different holes in the radiator support.
Here's the question....on the drivers side where the radiator mounts up to the radiator support, it mounts with 2 bolts. These bolts screw into 2 bushings with internal threads. They need to be moved from the 21" mounting holes to the 23" mounting holes. How do I remove them and move them over. I don't want to just start muscling them out and tear them up and end up having to buy new ones. It almost appears that the bushings can separate into two halves? Let me know if you have ever moved them or replaced them yourself. Thanks
klow is offline
post #2 of 7 (permalink) Old Jul 23rd, 11, 09:42 AM
mark
mark x22's Avatar
Re: New radiator and mounting
Buy new ones old ones probably aren't coming out in one piece . They swell up on the inside . https://www.napaonline.com/Catalog/C...282392296&An=0
mark x22 is offline
post #3 of 7 (permalink) Old Jul 23rd, 11, 09:47 AM Thread Starter
Kraig
Thats easy enough. Especially if I can run down to the local parts store. Sorry for the stupid question but thanks for the smart reply.
klow is offline
post #4 of 7 (permalink) Old Jul 23rd, 11, 10:36 AM
Alumitech is an excellent choice! Who ever suggested that is brilliant!
69 Pace Car and 69 Hard top
srode is offline
post #5 of 7 (permalink) Old Jul 23rd, 11, 11:30 AM Thread Starter
Kraig
I went back to that previous post and......Steve, thank you. I didn't realize you even told me to go with the bigger radiator. I knew someone had mentioned Alumitech but didn't realize you had gone the bigger radiator route. Knowing that now, did you just bolt it right up? Or did you cut the radiator support to open up the opening to allow more air into the radiator? Do you have any pictures of that area/setup? Thanks again Steve.
klow is offline
post #6 of 7 (permalink) Old Jul 23rd, 11, 11:38 AM
Kraig, I let the restoration shop install it, they did not cut the core support - you don't need to do that. The orginal core support is no different between BBC and SBC which is why you have the 2 sets of holes on the DS for mounting. They have it till mid next week or I would gladly take some pictures for you. I can when I get it back but am guessing you will have it fixed by then. For a fan shroud I ordered NOS shroud from GM Parts Direct for a 68 AC camaro using the part number from CRG. It's wider than the original on the 60 camaro to fully cover the radiator and mount on the shroud tab Alumitech installed. You WILL NOT have any cooling problems with that thing in there!
srode is offline
post #7 of 7 (permalink) Old Jul 23rd, 11, 11:52 AM Thread Starter
Kraig
Great!! I'm getting stoked that I will finally be able to drive the ol girl around again. I've missed it all summer long.
klow is offline
