Vintage Air - Team Camaro Tech
post #1 of 5 (permalink) Old Jul 25th, 11, 09:25 PM Thread Starter
Tad
Vintage Air
Can a pusher fan be added in front of the condensor to help the ac system to work better.
Tad Frahm is offline
post #2 of 5 (permalink) Old Jul 26th, 11, 10:18 AM
Jeremie
Re: Vintage Air
I would call the vintage air techs. I have talked to them and they are real nice, and helpfull.
69 327/332hp Le Mans Blue
71 C-10
MTN10 is offline
post #3 of 5 (permalink) Old Jul 26th, 11, 02:40 PM
Greg
Re: Vintage Air
My take is the condensor doesn't need help if all insructions are followed.
The correct size shroud, with the correct size fan blade installed in the correct position relative to the shroud, should be enough.
It is a closed system, and anything you do to minimize all vent leaks, window leaks, door leaks, good insulation etc, only helps the cooling efficiency.
1969 RS/SS Vert
1031 Engineering llc
chops is offline
post #4 of 5 (permalink) Old Jul 27th, 11, 10:59 AM
Re: Vintage Air
Moving air past the condenser is essential to good cooling and long system life.
GM added supplemental pusher fans on tow vehicles.
Does that answer your question?
71 Camaro 355 NA
11.1650 @ 119.30
1.5028 60'
hhott71 is offline
post #5 of 5 (permalink) Old Jul 30th, 11, 02:14 PM
Joe
Re: Vintage Air
What set up do you have currently? i.e. factory 4 blade fan/shroud, size of radiator. If you are adding Vintage Air to a non air car, you may need go get a larger radiator, 5 blade clutch fan , etc. Personally, when I installed the VA setup, went to a larger aluminum radiator with dual puller electric fans on at 195 off at 180). Probably didn't need them for normal driving, but this setup really helps when it's 90 degrees, and you are at idle in traffic for long periods.
joesauer is offline
