water temp fluxuating - Team Camaro Tech
post #1 of 10 (permalink) Old Oct 9th, 11, 08:06 AM Thread Starter
Tony
Send a message via AIM to tony -Di
in my 67 engine 350 .standard trans A/C Vintageair origanal A/C car . i Have a water temp gage installed the probe is in the intake manafold on the left side of the thremastat housing . when driving the water temp goes to 190 to 210. and then i look over and the needle is climbing it will go over 300 and the thermostat opens it will drop back to 210 .and keeps happining and inbetween it will peeg the needle high . I have changed the thermastat twice ,i have run the heat ,yesterday i went on a two hour ride to a show and two hours back and it did it both ways . it allso feels like the defroster heat wasnt not as hot as it could be it worked because the windows would fog quick and when i turned on the defrost it cleared quick . i was wounderin if and how to check the valve the controls the heater that in in the hot water hose in the engine compartment it is vacuum operated
thanks for if anyone has any sugestions
tony
tony -Di is offline
post #2 of 10 (permalink) Old Oct 9th, 11, 08:20 AM
Re: water temp fluxuating
Are you sure you don't have a wiring problem, maybe a short to ground?
69 Pace Car and 69 Hard top
srode is offline
post #3 of 10 (permalink) Old Oct 9th, 11, 09:18 AM
I would do the following:
1. Test thermostat in a pan of water and a known thermometer measuring the opening temp and when fully open.
2. Visit Radio Shack or a TV repair and get a 0-500 ohm potentiometer/rheostat and connect the gauge wire from the sensor to the center rheo/pot post and one of the other two legs to ground and adjust the pot/rheo for the same reading on the gauge as the t/stst temperature plus 10.
3. Once you do Step 2, run the engine then disconnect the gauge wire and measure the resistance from the stud to ground. The sensor resistence should be close to the gauge value. If sensor reads lower, then get another sensor.
4. If the temp gauge is OE, a Standard Motor Products sensor p/n TS6, might be the direct replacement.
5. Shoot the manifold with a temp gun to read its temp and compare with present gauge set-up. Should be close.
If the engine is hotting as hot as you say, you would know the minute you open the hood, your foiace will feel very hot as if you stuck your head in a preheated oven.
I might do Step 5 first.
post #4 of 10 (permalink) Old Oct 9th, 11, 12:48 PM
Steps
Follow what he guys say above because GM idiot light comes on at 235 deg..and if u are hitting much above that u WILL be blowing head gaskets and sezing up the engine, which it sounds like u have not done so.
A note: I always recomend running idiot light and gauge...a red light flash up on the dash is instant, a gauge go high may not be noticed on say a road trip...hence why track cars also run idiot lights.
Steptoe is offline
post #5 of 10 (permalink) Old Oct 9th, 11, 04:53 PM
george
Good tips as posted above^.Just would like to add.. air in the system will bring on similiar issues.It is crucial to burp all air, or steam pockets will occur and skew any temp sensor readings.If in doubt..jack up the front end while filling to aid in purge.Point is..to get the radiator fill opening higher than the t-stat housing..as you well know.. air likes to go up and out if allowed.
George
68 Camaro
8-71 blown 461 Rat on E-85
fatblock is offline
post #6 of 10 (permalink) Old Oct 9th, 11, 06:14 PM
DT
Donny
DT's Avatar
X2 a bad ground will peg the needle also.
DT is offline
post #7 of 10 (permalink) Old Oct 9th, 11, 09:30 PM
Steps
Damn that sounds like hard work
Park the wheels on a couple 4x2s or up on a kerb....or up the drive slope doesnt take much...and air locking is very rare anyway.
Steptoe is offline
post #8 of 10 (permalink) Old Oct 11th, 11, 04:36 PM Thread Starter
Tony
ok first thanks for all the input . the gage is not a wired it is a bulbed type . but i think the sugestion about air might be what is happening because the temp bulb is in the intake manifold in the same port that the thermostat is in and if the water boiles or if there is air in the port before the thermostat opens and lets the cooler water in it might be what is happening
tony -Di is offline
post #9 of 10 (permalink) Old Oct 11th, 11, 08:26 PM
Steps
Nope....
IF u have the CORRECT thermostat in in it will have a small bleed hole ..there fore the water before and after will be the same
Air locks are very rare, and IF u had followed suggestions above then u would have raised the font of the car...on a jack or kerb or bit of wood, what ever removed the cap, topped it up and replaced.....eliminated that.
have u the CORRECT cap on it yet...they are only a couple bucks...and little effort.
Have u checked the temp gauge is reading correct?
Other than the buying of the cap everything is free and only a couple minutes to carry out.
Unlees these VERY BASIC steps are taken then we are just banging our head aginst a brick wall.
Keep in mind several of us guys above are not just therorists who have read a few manually, each of us has decades of hands on experiance and knowledge.....EACH.
Steptoe is offline
post #10 of 10 (permalink) Old Oct 19th, 11, 08:04 PM Thread Starter
Tony
ok I havent had a chance to get here to report , i jacked the car opened the cap which is not a year old , as i topped it off i could hear it gerbling i left about an inch from the top i havent had a chance to take her out i will report back after i do
tony -Di is offline
