fan shroud - Team Camaro Tech
post #1 of 3 (permalink) Old Dec 21st, 11, 07:02 PM Thread Starter
anthony
fan shroud
I have a 67 camaro with long water pump and a 4 row radiator and need help with which fan shroud i should buy since 67 came with short water pump. thanks
alanier is offline
post #2 of 3 (permalink) Old Dec 22nd, 11, 02:12 AM
Re: fan shroud
A 69 SBC shroud will give you the correct placement of the fan inside the shroud depth wise and will work assuming you have a stock fan clutch and fan and a non AC radiato (21")r. If you have your original shroud, it will work on a 21" radiator, the fan will just be about an inch deeper into the shroud.
The AC radiators for 67/68 are wider (23" instead of 21") and you would need to use a 67/68 AC shroud with it. As iwth an original shroud, this set up will put the fan about an inch deeper into the shroud.
69 Pace Car and 69 Hard top
srode is offline
post #3 of 3 (permalink) Old Dec 22nd, 11, 04:44 PM Thread Starter
anthony
Re: fan shroud
thanks, car has flex fan and radiator is 23 so I will get ac shroud. Thanks again
alanier is offline
