67 Camaro AC problem - Team Camaro Tech
post #1 of 16 (permalink) Old Dec 31st, 11, 12:35 PM Thread Starter
Question 67 Camaro AC problem
AC and blower motor stopped working on 67 Camaro. Started operating intermittently and then totally went out. I ran new in-line fuse and wire to relay, replaced relay and then installed new blower switch in AC/HEATER assembly. Still no luck.
I understand that the blower motor will only operate if circuits are closed. I am at a loss eclectically!
Can anyone tell me if I should be receiving live current back to the AC blower switch or does it operate based on resistance?
Any advice or suggestions would be greatly appreciated.
Monty
montypeek is offline
post #2 of 16 (permalink) Old Dec 31st, 11, 12:47 PM Thread Starter
Question Help with 67 Camaro AC
Monty
post #3 of 16 (permalink) Old Dec 31st, 11, 02:15 PM
Re: 67 Camaro AC problem
If OE A/C system, I would jumper battery power to blower to see if it does work continously. Relay is only for high speed. A 40+ yr old motor may be tired and at its end of life.
If A/C compressor stopped working, corrosion on fuse sockets/clips or high pressure switch stuck open.
More to come later, dinner is being served.........
post #4 of 16 (permalink) Old Dec 31st, 11, 03:04 PM Thread Starter
Everett, thanks - AC Compressor will not kick on. Blower motor worked on low and medium for a while. High speed stopped working first. That is why I tried the relay replacement.
Can you tell me how to check to see if the pressure switch is stuck ?
Thanks, Monty
post #5 of 16 (permalink) Old Dec 31st, 11, 05:51 PM
john
wagonman's Avatar
I didnt know first gens had a high pres switch.
Anyway its easy to troubleshoot.
The high press switch is a safety device desinged to open and disable the system in an exccesive presure scenario.
Check the switch with an ohm meter while the system is off(de-engergized).The swich should be closed and have continuity.
Remember,I'm not making this stuff up!
1969 rs/ss 396 350hp/4spd conv a/c,pw,ps,foldown
1968 Z/28 crossram- j/l8 conv pw,ps,foldown
1963 nova ss 350/4spd conv a/c,ps,pt
1963 nova 400 4dr 6cyl/700r4 a/c
2006 GT/5spd mustang conv
wagonman is offline
post #6 of 16 (permalink) Old Dec 31st, 11, 05:53 PM
john
wagonman's Avatar
If the system has a low press switch it will work as follows.
It will have continuity during normal pressure.The switch will be closed.
When low press happens the switch will open and disable the system.
wagonman is offline
post #7 of 16 (permalink) Old Dec 31st, 11, 07:50 PM
Theres no high or low pressure switch on a first gen AC system, the compressor will run if the switch is put in the AC position and the hoses were disconnected. There is a low temperature switch on the passenger side of the underhood suitcase that drops the clutch out of the circuit when the air temp in the duct is less than 29 degrees. The inline fuse in the wire gutter at the back of the engine compartment only feeds the high speed fan circuit. The relay on the suitcase is energized by power from the switch in the dash, and it connects the wire from the fuse directly to the fan lead. All other speeds have power supplied from the dash circuit and power goes thru the resistors on the top of the suitcase. If you have no fan speeds at all the problem is in the power circuit under the dash, or the blower speed selector switch.
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
Mark C is offline
post #8 of 16 (permalink) Old Dec 31st, 11, 09:46 PM
Thank you, Mark. Appreciate the info.
post #9 of 16 (permalink) Old Jan 1st, 12, 09:50 AM
click's Avatar
Monty, I merged your 2 threads on your a/c issue. Lets keep them all together in one place so folks remember where they were helping you
click is offline
post #10 of 16 (permalink) Old Jan 2nd, 12, 02:58 PM Thread Starter
Jim, Thanks, New at posting and made a mistake. Thanks for catching it.
post #11 of 16 (permalink) Old Jan 3rd, 12, 10:16 AM
Michael
If you have a reasonably stock '67 AC , I'd check the rubber contact seal on the vacuum operated switch can that provides power for the entire AC system.
It's located on the inside AC controls and has a flat two blade connector going into the side of the vacuum can.
You can forget that other high/low pressure info.
mahunt is offline
post #12 of 16 (permalink) Old Jan 3rd, 12, 03:42 PM Thread Starter
Thank you Michael ! I will check it. I assume if the rubber cap is cracked (which mine is) that might be the problem. ( or at least part of the problem )
post #13 of 16 (permalink) Old Jan 4th, 12, 04:25 AM
Corey
Yes the rubber cap is the A/C clutch switch if yours is cracked and leaking vacuum I would have to say that would cause intermittent clutch activity. Until the crack gets to the point that vacuum can no longer make the contacts connect then you wont have any clutch operation. If you want jumper the two wires there and see if the compressor kicks on. If it does then at least one problem is solved. As for the blower motor I believe you need to check the basics with power and ground to blower motor and to switches. Sometimes if blower motors go back a simple tap with hammer on motor end will get them to turn a little confirming bad blower motor. Good luck!
vics67rs is offline
post #14 of 16 (permalink) Old Jan 4th, 12, 08:28 AM
at least you can buy the rubber replacement cap but the entire switch is a little harder to find.... make sure to keep the metal disk in the cap because they only sell the rubber part.
brandan-
1969 Chevrolet Camaro 396 SS X-66
1967 Chevrolet Camaro RS Convertible
Brandan is offline
post #15 of 16 (permalink) Old Jan 4th, 12, 03:15 PM Thread Starter
Brandon, Thanks - you are right! been trying to find replacement control switch for a few days with no luck. Thanks for your advise. Monty
