'69 Camaro SB POA GM Part Number Needed - Team Camaro Tech
post #1 of 12 (permalink) Old Jan 20th, 12, 03:04 PM Thread Starter
Bruce
Anyone know what the GM part number is for a stock SB AC POA valve?
'68 el Camino SS 396/325 hp, 4 Spd, 3.31, Buckets, AC
'72 el Camino SS, 454 LS5, 4 Spd, 3.73 LSD, Buckets, AC
'75 el Camino SS, 400 SB, Turbo 350, AC, Swivel Buckets, PW, PDL
'87 el Camino Choo Choo SS (305 TPI, 200R4, 3.73 LSD)
'87 Buick GN Hardtop
PaceCarNut is offline
post #2 of 12 (permalink) Old Jan 20th, 12, 04:19 PM
Vintage 68's Avatar
Re: '69 Camaro SB POA GM Part Number Needed
Pretty much all the non Full-Size models from the mid 60's to the mid 70's used the same expansion/POA valve set-up.
They mounted differently depending on model though, so the clamp(s) were different.
GM listed that POA (or 'Freon Evaporator Control Valve') as Group 9.198 and part #5910593
The SBC clamp assembly was Group 9.199 and the part # 3902244
Don't have any notes about the BBC clamp
1968 Convertible
Some trucks
Vintage 68 is offline
post #3 of 12 (permalink) Old Jan 20th, 12, 04:19 PM
69-Pace's Avatar
Do you mean an Pilot Operated Absolute valve from the receiver dryer? 15-51 Type-2?
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #4 of 12 (permalink) Old Jan 20th, 12, 05:40 PM Thread Starter
Bruce
Thanks!
Any idea what this part number came off of?
5910521
Came across an NOS one locally at what I consider to be a reasonable price. Wondering if it will do the job for my Z-10?
post #5 of 12 (permalink) Old Jan 20th, 12, 05:53 PM
Tony
from what i was able to find out 1965-1967 gm vehicles
tonycamaro is offline
post #6 of 12 (permalink) Old Jan 20th, 12, 11:20 PM
Vintage 68's Avatar
Red face Re: '69 Camaro SB POA GM Part Number Needed
IIRC - and as stated - it was the common early/mid 60's evap. valve prior to the POA assembly.
No idea what the specs and ratings differences between the two area, but if I can find my 70's GM/Frigidaire/Harrison cat. I may be able to find them ...
1968 Convertible
Some trucks
post #7 of 12 (permalink) Old Jan 21st, 12, 06:37 AM Thread Starter
Bruce
Just curious, but what would a good price be for the 5910593 POA, used but in condition?
post #8 of 12 (permalink) Old Jan 21st, 12, 01:06 PM
Vintage 68's Avatar
I've seen them go for anywhere from @$60 up to $250 or so - but you don't see then to often ...
Here's a 'used' one on eBain - http://www.ebay.com/itm/67-68-69-70-...-/360423833702
1968 Convertible
Some trucks
post #9 of 12 (permalink) Old Jan 21st, 12, 01:40 PM Thread Starter
Bruce
Here's a 'used' one on eBain - http://www.ebay.com/itm/67-68-69-70-71-72-Chevelle-Camaro-POA-B-Valve-A-C-AC-/360423833702
Yes, that's the one I saw as well on eBay. Seems like a fair deal.
There is a POA part #5910521, NOS, up on Craigslist locally for $85, but probably for the extra $$ best to get the right one.
post #10 of 12 (permalink) Old Jan 23rd, 12, 07:03 AM
Are you going to use R12 or 134a? You can purchase a POA valve from Classic Auto Air that has been calibrated for 134a.
A/C Tech Guys is offline
post #11 of 12 (permalink) Old Jan 23rd, 12, 07:34 AM
Vintage 68's Avatar
Wink Re: '69 Camaro SB POA GM Part Number Needed
You can, but all the replacement units I've seen so far are far from 'stock' in appearance ...
1968 Convertible
Some trucks
post #12 of 12 (permalink) Old Jan 24th, 12, 02:22 AM
parkbrau's Avatar
Originally Posted by PaceCarNut View Post
Thanks!
5910521
Make note of the position of the external equalizing line. Some are positioned differently than others. If you get the wrong one your equalizing line wont line up. Thats the only difference in 60s/70s POAs, that line. Check with Pace car jeff, he always has those for sale.
parkbrau is offline
