Heater Blower 69 Camaro (AC not installed) - Team Camaro Tech
post #1 of 8 (permalink) Old Feb 17th, 12, 03:23 PM Thread Starter
Bill
can anyone tell me the easiest way to check why my heater fan does not come on? I checked fuse box, theres power there, I also checked the fan switch and its getting power, but only to the medium setting (will need new switch), but the fan still does not work. Also, how do I access the fan?
Baso is offline
post #2 of 8 (permalink) Old Feb 17th, 12, 05:30 PM
Mickey
Moonpie's Avatar
Re: Heater Blower 69 Camaro (AC not installed)
The fan gets its ground through the case so if you painted everything the fan may not be getting grounded. Fan access is easy. There are several screws holding it onto the outside heater case on the firewall. Unbolt and open the circular looking thing. It is the fan. With the fan out run a hot wire from the battery positive post to the one plug, put the edge of the case against the ground post of the battery and it hopefully will run.
Moonpie is offline
post #3 of 8 (permalink) Old Feb 17th, 12, 06:32 PM Thread Starter
Bill
Mickey, Thanks. Did you mean on the firewall under the dash below the glove comp.? If so, I will give it a go tomorrow. thanks again!
Bill
Baso is offline
post #4 of 8 (permalink) Old Feb 18th, 12, 04:04 AM
Kevin
KevinW's Avatar
I think AC fans are different. The AC case is fiberglass(ish) not metal, so the ground path is different. Are there two wires going to the fan? Inside the pass fender under the hood hinge.
Kevin
KevinW is offline
post #5 of 8 (permalink) Old Feb 18th, 12, 07:22 AM Thread Starter
Bill
Kevin - Thanks; can't even see the fan due to its location, but there is a black wire hanging loose between the AC case and the wheel well. Man this is going to be painful since it doesnt look like there is an easy way to reach the fan. Is removing the fender the only way? cant be done by unbolting the heater case under the dash?
Baso is offline
post #6 of 8 (permalink) Old Feb 18th, 12, 07:37 AM
prostreet69camaro's Avatar
Easiest way is remove the fender. Or you can take the fenderwell out. Either way is a pain.
prostreet69camaro is offline
post #7 of 8 (permalink) Old Mar 13th, 12, 02:26 PM Thread Starter
Bill
Thanks for all of the suggestions, but a little bit of contorsioning and I found a bad ground, imagine that...
Baso is offline
post #8 of 8 (permalink) Old Mar 13th, 12, 06:34 PM
Job well done, Bill.
Yes, it would be nice to have an arm with a second elbow............
