Heater hose replacement on a 67 Camaro - Team Camaro Tech
post #1 of 3 (permalink) Old Feb 19th, 12, 10:33 AM Thread Starter
Greg
I am only replacing the heater hoses. The old ones are worn out. Is it necessary to drain the radiator to do this? I have heard yes and no.
Thanks.
Tarheelkidd is offline
post #2 of 3 (permalink) Old Feb 19th, 12, 11:21 AM
Re: Heater hosereplacement on a 67 Camaro
In an open system, the coolant will try to reach a level even with the lowest point open to the atmosphere. So, if the level in the radiator is higher than the lowest point you will be opening up, then you will be discharging from that lower point.
In other words, because the heater hose nipples on the intake and water pump are lower than the level in the radiator (assuming you have it filled within 2 or 3 inches of the top of the rad, as recommended for an open system), you will get coolant gushing from both of those when the heater hose is removed.
If you drain the level in the rad down below the lowest point, then no gush. So, you do not need to drain completely, but at least some.
Eric
Eric Kammerer is offline
post #3 of 3 (permalink) Old Feb 19th, 12, 12:45 PM Thread Starter
Greg
Re: Heater hose replacement on a 67 Camaro
Thanks for the reply/explanation. Your explanation makes perfect sense. Off to get some anti freeze.
