Heavy Duty Fan Clutch vs Standard Fan Clutch - Team Camaro Tech
post #1 of 11 (permalink) Old Feb 23rd, 12, 05:21 PM Thread Starter
Benito
Whats the difference? I only ask is because I ordered this:
HAYDEN Part # 3568
Flex Fan For Standard Rotation Standard Duty Thermal Fan Clutch
Flex Fan For Standard Rotation Heavy Duty Thermal Fan Clutch
and now Im about to order the clutch....Hayden makes a thermal heavy duty one or this one from napa which is also made by Hayden....... I also have a new 23inch 4row in the garage.....
Part Number: TEM 271303
Product Line: NAPA Temp
Attributes:
Fan Clutch Fan Mount Height : 1.63"
Fan Clutch Height : 3.47"
Fan Clutch Overall Diameter : 7.25"
Fan Clutch Pilot Depth : .63"
Fan Clutch Pilot Diameter : .63"/.75"
Fan Clutch Rotation : STD
Fan Clutch Type : C
Warranty:
See Manufacturer for Warranty Information
Important Information:
w/ Heavy Duty Fan Clutch
w/ Standard Rotation Fan Clutch
malinois1983 is offline
post #2 of 11 (permalink) Old Feb 23rd, 12, 05:26 PM
Steiner
Re: Heavy Duty Fan Clutch vs Standard Fan Clutch
You have to make sure the fan speed is rated for the clutch and max engine speed.
Standard duty clutch spins fan about 60% of engine speed.
Heavy duty clutch spins fan about 80% or more of engine speed.
Standard duty fan is usually rated for about 4000 RPM or so which would be good to about 6500 engine RPM but could come apart at high speed with a heavy duty clutch.
'69 Camaro
500hp/538lbft
Steiner is offline
post #3 of 11 (permalink) Old Feb 24th, 12, 03:10 AM Thread Starter
Benito
Ill call rock auto to verify today but the fan part did say good for heavy duty thermal clutch fan(posted above)
post #4 of 11 (permalink) Old Feb 24th, 12, 03:21 AM
Steiner
You gotta wonder why they don't just make one fan. Must've been designed by the same person who did the small block and big block heater cores.
'69 Camaro
500hp/538lbft
Steiner is offline
post #5 of 11 (permalink) Old Feb 25th, 12, 11:57 AM Thread Starter
Benito
Here is something else I find funny. I get my fan in today and open the box to check it out. Well on rock auto and everyone elses website where they sell this fan made by hayden that it will work with my SBC 350.....So I open the box and it say on the warning do not use with a high performance engine or anything over 250 cubes(4.1l) Ive seen a few people run that fan too.
post #6 of 11 (permalink) Old Feb 25th, 12, 12:09 PM
Steiner
When I pull up Hayden 3568 the image I get is for a flex fan, not a clutch fan. Does it have a large hole in the middle for the clutch shaft to pass through like this one linked below? It's the one I use with a standard duty thermal clutch.
http://www.summitracing.com/parts/FLX-5718/
'69 Camaro
500hp/538lbft
Steiner is offline
post #7 of 11 (permalink) Old Feb 25th, 12, 04:51 PM Thread Starter
Benito
no it does not have that hole just 4 holes for holes....So why does it say on rock auto that its for a fan clutch?
Let me guess I have the wrong stuff even though I called and confirmed that what I was getting was right???
post #8 of 11 (permalink) Old Feb 25th, 12, 07:43 PM Thread Starter
Benito
Also if thats not correct.....is this the right one? http://shop.stevescamaroparts.com/67...?categoryId=-1
Just trying to make sure I can use with a heavy/severe duty clutch
post #9 of 11 (permalink) Old Feb 25th, 12, 09:23 PM
Ed
The one linked above from Steves Camaro Parts is the mounting style to use with a fan clutch
freezined is offline
post #10 of 11 (permalink) Old Feb 26th, 12, 04:23 AM Thread Starter
Benito
Great so the one sitting on my couch is the wrong one....wa wa waaaaa
post #11 of 11 (permalink) Old Feb 26th, 12, 06:19 PM
Steiner
Maybe there's a clutch design somewhere that works with it....but it ain't a first gen one. I've got one that looks identical to that which used to be direct mounted with a spacer.
'69 Camaro
500hp/538lbft
Steiner is offline
