Adhesive ?? - Team Camaro Tech
 1Likes
  • 1 Post By KevinW
post #1 of 9 (permalink) Old Mar 28th, 17, 04:59 AM Thread Starter
67 455 Bird ragtop's Avatar
Adhesive ??
Please hold any potential laughter until the end of this post
Given the state of adhesives today has anyone used or investigated the possibility of using either a body adhesive or one of the better heavy duty adhesives to attach mounting brackets to a radiator ?? Just a thought.
67 'Bird vert 455 JW TH400 KRE d-port 310 cfm heads H-beam rods Comp Cam 305-AH-8 cam w/1.65 rockers Ford 9" 3.55 Detroit Locker M/T Radials 31x18x15 on Convo Pro 15x15s
67 455 Bird ragtop is offline
post #2 of 9 (permalink) Old Mar 28th, 17, 06:09 AM
Re: Adhesive ??
JB Weld works great.
Any two-part epoxy adhesive should work.
Clean mating surfaces with BraKleen®, lacquer thinner, or 99% alcohol - and don't touch the clean surfaces.
post #3 of 9 (permalink) Old Mar 28th, 17, 06:39 AM
Re: Adhesive ??
If I did something like this I would make sure to have some kind of backup restraint to hold it in place if the joints let go. It could get ugly fast otherwise.... Could be something as simple as a couple of discretely hidden zip ties, but I would have something for sure.
1959 El Camino project
1957 Buick Caballero project
dhutton is offline
post #4 of 9 (permalink) Old Mar 28th, 17, 06:41 AM
Kevin
KevinW's Avatar
Re: Adhesive ??
You need to factor in the heat cycles for a radiator support. Most body adhesives dry hard, so the heat/cold/heat might break them loose.
Mike_S likes this.
Kevin
KevinW is online now
post #5 of 9 (permalink) Old Mar 28th, 17, 08:26 AM
Re: Adhesive ??
You could try JB Weld for Exh manifolds.
COPO is offline
post #6 of 9 (permalink) Old Mar 28th, 17, 11:25 AM
Rick
Re: Adhesive ??
No way. The carnage would be bad if it broke.
69 COPO clone, 461" BBC 11.25:1 Compression
840 Rec Heads (2.25/1.88) AED 850 HO carb
Orig Exhaust Manifolds
Straub (Clay Smith) cam, 288/300 .600/.569 109.
TH400, 3500 stall, 4.11 12 bolt posi
rp930 is offline
post #7 of 9 (permalink) Old Mar 28th, 17, 03:49 PM
Lynn
Re: Adhesive ??
Not laughing. Given the advancement in modern adhesives, I honestly believe something out there COULD work. PC-7 epoxy comes to mind. That stuff is amazing.
PC Epoxy
However, finding something that DEFINITELY WOULD work is another matter. I think the heat cycles may be a killer.
If it were me, I would just have it soldered.
Lynn
bilodeaulynn is offline
post #8 of 9 (permalink) Old Mar 28th, 17, 06:18 PM
Re: Adhesive ??
CP Packaging | VisionPak
Take a look at the rollstock packaging machine at the above link. Mostly stainless. Can be 12 meters long. Pick it up and move around with a forklift. If you are in the northeast and know the Dietz And Watson label nearly all their retail deli is packaged in these machines. Frames are glued structural shapes. As crazy as it may seem this is in our future too.
3d cad is offline
post #9 of 9 (permalink) Old Mar 29th, 17, 03:26 AM
Greg
pittpens24's Avatar
Re: Adhesive ??
I used JB Weld on my radiator brackets for my '05 Jeep wrangler - daily driver. Not sure how or why, but the top 2 brackets cracked off the rad, but the bottom 2 were fine. The rad wasn't leaking so I decided I'll just get whatever time I can out of the JB Weld and then replace it. Well it lasted about 5 years and didn't fail - the rad did and started leaking. Heat cycling was not a problem.
'68 Camaro with RS conversion
Moser 9" with 4:11
Tremec T-56 Magnum 6 speed
572 BB - CM Engines
pittpens24 is offline
