core support pics ?? - Team Camaro Tech
post #1 of 5 (permalink) Old Apr 2nd, 17, 12:29 PM Thread Starter
67 455 Bird ragtop's Avatar
I'm getting ready to build some mounts for the Griffin radiator for my 67. Does anyone have have some good pics of a stock radiator mounted ?? My preference would be of a pic without a motor installed so I can how high it's mounted on the core support as well as what is mounted to the support on each side. I know the battery tray is on the right side. Not sure what all is mounted on the left side.
67 'Bird vert 455 JW TH400 KRE d-port 310 cfm heads H-beam rods Comp Cam 305-AH-8 cam w/1.65 rockers Ford 9" 3.55 Detroit Locker M/T Radials 31x18x15 on Convo Pro 15x15s
67 455 Bird ragtop is offline
post #2 of 5 (permalink) Old Apr 3rd, 17, 07:52 AM
Re: core support pics ??
I don't have any stock pics but here are some pics of a Griffen exact-fit radiator mounted if this helps.
Thanks, Jim
ID:	179770   Click image for larger version
ID:	179778   Click image for larger version
ID:	179794   Click image for larger version
ID:	179802   Click image for larger version
No School Like The Old School!
67 RS 4 Speed with Big Block conversion
12 bolt with Richmond 3.90's
4Speed67CamaroRS is offline
post #3 of 5 (permalink) Old Apr 3rd, 17, 08:05 AM
Exact same radiator as my Entropy but I use a fan clutch set up with 7 blade fan. Be sure to use the rubber mounted well nuts on the drivers side as this keeps the core from flexing. and breaking apart.
Pass side is a solid mount.
TC # 349
zdld17 is offline
post #4 of 5 (permalink) Old Apr 3rd, 17, 09:54 AM
'69 SS396 X66 L34 08D M21 BS
460ci Gen VI 9.75:1 AED 950 carb
Semper Fi!
HawkX66 is offline
post #5 of 5 (permalink) Old Apr 3rd, 17, 01:07 PM Thread Starter
Thanks, Jim
