69 AC/heater core question! - Team Camaro Tech
 2Likes
post #1 of 20 (permalink) Old Jun 10th, 17, 05:12 PM Thread Starter
TJ
I had my AC charged for the first time and only gets down to about 60 degrees coming out of the vent. I note that my heater core is still circulating antifreeze because the vacuum switch in the engine compartment doesn't have vacuum to it in order to shut off the flow via that heater control valve.
So my question is: would the flow going to the heater core actually HEAT up the air coming out from the AC vents or would the heater core simply be like a radiant heater sitting by the passengers feet (not actually heating the AC air but heating the area right by their feet?)
ttwo is offline
post #2 of 20 (permalink) Old Jun 10th, 17, 05:32 PM
Re: 69 AC/heater core question!
Yes it would.
There may be a hose connection on TEMP switch to engine vacuum to valve for shutting off core flow.
post #3 of 20 (permalink) Old Jun 10th, 17, 07:31 PM
Ed
Yes is right! I'm in the process of sorting out my AC on my 69. Between the electrical and the vacuum there's a lot that can go wrong.
I believe I've solved my electrical issue but am waiting for a new fan blower switch as that's where I believe my issue is.
Regarding the vacuum, I too was only getting 60 degrees at the vent after charging and just noticed the vacuum line that runs to the canister inside the drivers fender well is disconnected from the intake manifold. I just hooked it back up but won't have a chance to try it out till tomorrow or Monday. I'm concerned that it was disconnected for a reason but who knows.
I will need to pull the temp controls out to change the switch and will inspect and test the vacuum switch under the dash.
Ed
emdoller is offline
post #4 of 20 (permalink) Old Jun 11th, 17, 07:16 PM Thread Starter
TJ
I think I am just going to put a manual heater core flow manual shut off valve in where I can cut the flow for the spring and summer and open it for the fall when I would actually use heat. What else does the vacuum do for the AC under the dash besides sending vacuum to close flow to the heater core in the engine bay? Is there any good diagram of this? I know it also goes to the kick panel vents but I just leave those shut anyway. Anything else that is important to the AC?
ttwo is offline
post #5 of 20 (permalink) Old Jun 11th, 17, 07:46 PM
Ed
The diagram you want to look at is in the assembly manual C60 E9. It will show you that in addition to the heater shut off it controls the two valves that allow you to choose inside air vs outside air.
Outside air is used for vent and AC normal or heat. Inside air is used for AC max.
Ed
emdoller is offline
post #6 of 20 (permalink) Old Jun 12th, 17, 06:08 AM
click's Avatar
I had the same issue years ago, solved the heat flow issue with a brass plumbing valve, the type used in Wirsbo floor heat tubing, got it at Ace Hdwe. It has the barbed ends and simple shut off bar on top.
http://www.carsbyjim.com/storage/Mis...utoffvalve.JPG
click is offline
post #7 of 20 (permalink) Old Jun 12th, 17, 06:34 AM
Ed
I'm going to try and get mine working with the vacuum lines. If not I may have to resort to adding a valve.
Ed
emdoller is offline
post #8 of 20 (permalink) Old Jun 12th, 17, 10:15 AM Thread Starter
TJ
This is what I ordered
ttwo is offline
post #9 of 20 (permalink) Old Jun 12th, 17, 12:52 PM
Manual valve, the best type.
1968RallySport likes this.
post #10 of 20 (permalink) Old Jun 12th, 17, 01:13 PM
George
The Classic Auto Air system I'm installing uses an electric heater valve on a slide switch. I'm not sure I understand the logic of having the valve half-open. I don't see it making much of a difference if the heater coil is full of water (and if the valve is open at all, I assume it will fill pretty quickly).
That said, the valve that comes with the kit is quiet and can be managed electrically. I'm guessing something similar can be found as a stock replacement from some car.
George
69 Base V8 Coupe (purchased in 1988)
Build Thread:
gkala is offline
post #11 of 20 (permalink) Old Jun 12th, 17, 02:24 PM Thread Starter
TJ
but in the end again would this actually make the air coming out of the vents warmer just because water is still going to the heater core???
ttwo is offline
post #12 of 20 (permalink) Old Jun 12th, 17, 02:29 PM
George
That's what I think. Haven't fully installed the system so I really can't comment on how it works in practice. I do think it works well just as a remote on/off valve. I don't think the core\evaporator unit has a mixing door on that system. I'm guessing they expect the mixed temp to occur from less heated water flow through the core.
George
Build Thread:
gkala is offline
post #13 of 20 (permalink) Old Jun 13th, 17, 06:32 AM Thread Starter
TJ
I installed the device above and now it is 51 degrees coming out of the vent? Not sure of what it should be but at least it is colder. I am using the R134 stuff and not freon
ttwo is offline
post #14 of 20 (permalink) Old Jun 13th, 17, 04:22 PM
Ed
Good news is it went in the right direction. For R12, it should get ~40F. There's lots of debate over R134 and it's ability or not to get that cold. Where you are isn't bad at all.
How much r134 did you put in? Did you check your pressures and have they changed since you charged indicating a potential leak? Just because there's no leak during the vacuum doesn't mean that there won't be one after you charge the system with much higher pressure albeit positive vs negative.
Ed
emdoller is offline
post #15 of 20 (permalink) Old Jun 14th, 17, 05:58 AM Thread Starter
TJ
I had the system charged by a station and they troubleshot the problem to the heater control valve not shutting and said I didn't have to pay for it until I was able to fix it and see that it worked fine. So now that it works I will have them check the charge again and if good then I might be golden!
ttwo is offline
