Vintage Air compressor and alternator mount question - Team Camaro Tech
 2Likes
  • 1 Post By mahunt
  • 1 Post By Vega
post #1 of 7 (permalink) Old Jun 21st, 17, 07:14 AM Thread Starter
I posted it in the vendor section, but will ask it here in a different way. I'd like to order a Vintage Air setup for my '69 BBC Camaro, and I don't want (can't afford) a serpentine setup, but I want the compressor on the passenger side and the alternator on the driver's side like a '68 BBC.
So I'm looking for decent looking aluminum or chrome mounting brackets that will locate the alternator and compressor in the normal (?) position, not high, not low, and I don't like the huge plate look of the VA brackets.
I have a long water pump, and also want to know if I'm going to have to swap in a short pump? Thanks in advance for the advice.-Mike
'69 LeMans Blue Coupe, White Interior, 030" over 454, Super T10 4-Speed, Holley 4150, Pertronix Ignition
CompCams XS274S, 781 Oval Port Heads, PYPES Full 3" SS Exhaust, Hooker Comp Headers, Wilwood Calipers/MC
JGC Steering Box, Helix Uppers/Lowers, ProForged BJs, SpeedHut Gauges, MOMO Steering Wheel, Budnik 17" Wheels
57vette is offline
post #2 of 7 (permalink) Old Jun 21st, 17, 01:48 PM
Michael
Re: Vintage Air compressor and alternator mount question
Tell the VA guys you have a 68 BB and get their brackets. If you don't like their brackets, I can't imagine how expensive shiny cool looking brackets will be.
If you are going to emulate the 68 BB setup, you'll need all the brackets to swap sides and location for the alternator and PS pump, which will require a short water pump, fan and radiator shroud.
130fe likes this.
mahunt is offline
post #3 of 7 (permalink) Old Jun 22nd, 17, 06:04 AM Thread Starter
Wow! May have to rethink this LOL. Whats the difference in the actual fans? Diameter, pitch? And is the '68 BBC fan shroud deeper or something else is different?
Just wondering out loud here... my main objection to the "standard" 1969 setup is the cluttered look of all the hoses in front of the block. Has anyone seen an alternate hose layout that isn't so fugly? 🤔
57vette is offline
post #4 of 7 (permalink) Old Jun 22nd, 17, 06:27 AM
Vega$69's Avatar
I've installed the 69 style VA set up on a BBC 69. The "cluttered look" can be addressed by running the lines from the compressor carefully with fittings and hoses for a neat install.
You can run custom hard lines that will greatly improve the look. More work then hose but way easier then swapping everything to opposite sides.
Other options are reduced barrier hoses and fittings that are more flexible and have smaller outside diameters or braided lines and stainless fittings from Gottashow.
57vette likes this.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #5 of 7 (permalink) Old Jun 22nd, 17, 08:27 AM Thread Starter
Hey John... That all sounds promising. Do you have any links to pix or articles on "cleaner installs" and hard lines? I'll also check out Gottashow.
57vette is offline
post #6 of 7 (permalink) Old Jun 22nd, 17, 09:54 AM
Vega$69's Avatar
Google AC custom hard lines. Take a look on Protouring.
Gottashow has braided. Relatively expensive but looks good.
Gotta Show Products Home Page Featuring Hot Rod Plumbing
https://www.philliprads.com/customacparts
Vega$69 is offline
post #7 of 7 (permalink) Old Jul 14th, 17, 06:56 AM Thread Starter
After all is said and done, think I'm going to stick with the compressor on the DS. Vintage Air has thinner hoses with an EZ Clip system where you can crimp the hoses with a pair of specialty pliers similar to PEX pliers... might even be the same.
My car has a single groove water pump pulley and a double groove crank pulley in front of the balancer. The VA PDF instructions show a triple groove crank and a double groove water pump pulley. Are these pretty much generic BBC pulleys as I see them on eBay?
BTW, I do have a long water pump, and also just wondering if the VA moves the alternator from its current position to further out?
57vette is offline
