New Radiator? - Team Camaro Tech
 1Likes
  • 1 Post By Vega
post #1 of 8 (permalink) Old Aug 7th, 17, 01:34 PM Thread Starter
Apprentice
Dustin
New Radiator?
I decided to buy an electric fan to cool my car instead of worrying about moving the radiator closer to the fan. Anyway, I may go with a new radiator to fit onto the new Camaro radiator mount that I bought as well (the one that is in there is not for a 68). What are your recommendations for brands and places to buy one? I read that 2 or 3 row/core is best with an electric fan. I was going to get a Flex a lite but the package I wanted, with a fan, was over $800. Thanks!
One more question, on that new radiator mount (see picture) for a 68 Camaro, there seems to be no "radiator pan" at the bottom of it; no support to hold it up. Is that something else you have to add to it or do you just use bracket and attach it to the mount?
sneeper69 is offline
post #2 of 8 (permalink) Old Aug 7th, 17, 01:37 PM
Banned
Chet
Sooooo, you don't want to move a radiator but you're willing to just replace the radiator and spend $800?
onefiness is offline
post #3 of 8 (permalink) Old Aug 7th, 17, 01:55 PM
Vega$69's Avatar
Re: New Radiator?
The radiator bolts to the core support. There is no bottom support
sneeper69 likes this.
Vega$69 is offline
post #4 of 8 (permalink) Old Aug 7th, 17, 03:37 PM
kevin
Re: New Radiator?
I have a Champion 3 core looks and cools great
flat tire is online now
post #5 of 8 (permalink) Old Aug 7th, 17, 05:34 PM
Re: New Radiator?
Before spending a bunch of $$$ you may not need to....Check your timing.
BUT, IF you still want to spend $$$, a good 3 or 4 core radiator and a Mark VIII or Taurus fan should help.
68 Camaro~LSx ~all motor
post #6 of 8 (permalink) Old Aug 8th, 17, 07:10 AM
Bruce
Re: New Radiator?
Go back original with a copper radiator and clutch fan with a stock fan shroud. No need to reinvent the wheel. . .never had a over heating issue even with my BB. . . .JMO
The Camaro Guy is offline
post #7 of 8 (permalink) Old Aug 8th, 17, 08:30 AM
Vega$69's Avatar
Re: New Radiator?
Aluminum Superior Direct fit. Dual 1" core
I use the EBay from Disrad with dual fans. A little over $500
Has cooled everything fine here in Vegas from SBC to LS3 and BBC with AC
Vega$69 is offline
post #8 of 8 (permalink) Old Aug 15th, 17, 09:59 AM Thread Starter
Apprentice
Dustin
Re: New Radiator?
Thanks for the suggestions. The Xtreme Flex a lite fan (3300 cfm) was installed last weekend. I moved the radiator over a little bit since it was offset, incorrectly. I ran it this weekend and even took it on the highway and it never ran over 190 in 85 deg weather! I had no problems! I can finally drive it and not worry about vapor lock or over heating (had lines rerouted before the fan)!!
The core support is not for a camaro and the radiator is not either but the fan solved the issue for now. I can upgrade the other stuff when the money permits, in the future, and when it's too cold out to drive it. That'll be a winter project
