Under dash heaterbox. - Team Camaro Tech
post #1 of 3 (permalink) Old Aug 26th, 17, 01:57 AM Thread Starter
Apprentice
Bjorn Ingar
I'm in the prosess on a frame off restoration on a 68 Camaro. Guess I will nead some help on the way. Have finishing the sheetmetall work and have started restoring the pile of small parts. Question : what colour and finish should the under dash heaterbox have?
57 Chevy Bel Air sport coupe (sold)
68 Chevy Camaro project
trifivenorway is offline
post #2 of 3 (permalink) Old Aug 26th, 17, 06:02 AM
Michael
Re: Under dash heaterbox.
I can only tell you for how I found my 67 heater boxes. They had a slight texture with a semigloss finish to them. I did a long search for the paint and found one that had the exact texture, and it also is the same texture as the top of the dash. It's Rustoleum 'Fine Texture" P/N 7220. I used this on the heater box and it also gives the semi-gloss finish. Use light coats over an already painted black base and just enough for the desired texture. I used this also on my dash top and it came out perfect (when a coat of flat black was applied over the textured finish). I compared that to my other original 67 and the textures are the same.
Hope this helps,
67 LOS SS/RS L35 Hardtop - Original w/UOIT
67 NOR SS/RS L35 Convertible - Restored
Mike_S is offline
post #3 of 3 (permalink) Old Aug 26th, 17, 10:50 AM Thread Starter
Apprentice
Bjorn Ingar
Thank you for the info. I will have to try and find if there is a dealer for this product here in Norway or at least I know a bit more what to look for.
