Brown AC Wire - Team Camaro Tech
post #1 of 6 (permalink) Old Sep 14th, 17, 09:33 PM Thread Starter
Probationer
Eric
Brown AC Wire
The brown ac wire in my 68 Camaro gets too hot to touch when my ac is on. Not even sure how the wire insulation doesn't melt. It's that hot. Anyone have any ideas as to what could cause this? Diverter switch, thermal switch, lo blo, fan switch, fan itself?
stope4Rev1 is offline
post #2 of 6 (permalink) Old Sep 15th, 17, 06:26 PM Thread Starter
Probationer
Eric
Re: Brown AC Wire
Maybe this post should be in ac and heating. Can someone move this to that category?
post #3 of 6 (permalink) Old Sep 15th, 17, 08:07 PM
scblucam's Avatar
Re: Brown AC Wire
Sounds like a dead short somewhere. Disconnect from the ac and turn it on. Does it still get hot?
68 302 M20 - 85 IROC Z
scblucam is online now
post #4 of 6 (permalink) Old Sep 17th, 17, 08:21 AM
Larry
Re: Brown AC Wire
I'm far from the smartest guy here, but for what it's worth ...
I have been working through my under dash (including heater) wiring quite a bit over the past few weeks.
That brown wire is the main power supply wire to your heat & A/C system from the fuse panel.
I don't know if that's helpful in any way (or maybe you were already aware), but it's what my diagrams show for 67,68 and 69.
I can't complain, but sometimes I still do.
Larry Madsen is offline
post #5 of 6 (permalink) Old Sep 17th, 17, 09:46 AM
Timmy
Re: Brown AC Wire
Hi Eric
As Larry Said, that Wire should be Protected by the Fuse in the Main Panel.
Check the FUSE Installed for the Heat A/C, Should be a 25 Amp.
If its getting Hot, there is probably a Load too high more than a Short to Ground, that would Blow the Fuse or Melt the Wire.
Timmy
Name:	Camaro Fuse Panel.jpg
1969 SS/RS Coupe 427BB 700R4 12 Bolt 4:11 A/C, High School Resto Mod
November 1968 Build Date
french69ssrs is offline
post #6 of 6 (permalink) Old Oct 1st, 17, 02:06 PM Thread Starter
Probationer
Eric
Re: Brown AC Wire
O.k. Think I figured it out. I had disconnected the wires to the compressor. They were sitting on the fender with the exposed metal flat against the fender. I moved this and the heat in the brown wire has disappeared. At same time, I also went and disconnected and reconnected all the wires to the various switches and relays. I guess that could have played a role but I doubt it. I'll keep an eye on the wire and see if it gets hot again.
