PWM Fan Controllers - Team Camaro Tech
 6Likes
post #1 of 33 (permalink) Old Oct 9th, 17, 01:21 PM Thread Starter
DT
Donny
DT's Avatar
PWM Fan Controllers
Anyone use a PWM fan controller with their electric fans ?? Thoughts, Doubts, Comments are all welcome. Derale seems to have one but the reviews make me skeptical of the performance and reliability.
DT is offline
post #2 of 33 (permalink) Old Oct 9th, 17, 02:03 PM
Re: PWM Fan Controllers
I was thinking of using one of these. Same guy makes the Vaporworx PWM fuel pump controller which works well.
constant temperature controllers
1959 El Camino project
1957 Buick Caballero project
dhutton is online now
post #3 of 33 (permalink) Old Oct 9th, 17, 04:48 PM Thread Starter
DT
Donny
DT's Avatar
Looks good Don.
DT is offline
post #4 of 33 (permalink) Old Oct 9th, 17, 05:19 PM
Vega$69's Avatar
I've used this on both LS and Non LS builds
Electronic Fan Controller 70 Amp
Fully programmable, the PAC-2750 will work with your existing water temp gauge, operating from the temperature sending unit already installed. A dedicated sending unit can be installed for applications without a water temp gauge. OBD II compatible vehicles can obtain the engine temperature from the ECM with the use of a BIM-01-2 (or previous BIM-01-1), purchased separately.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #5 of 33 (permalink) Old Oct 9th, 17, 06:32 PM
This is simple on/off fan control and not PWM. PWM (pulse width modulation) control turns the fan on and off at a high rate with a variable on/off duty cycle. This enables the fan to run with continuously variable speed and only as fast as needed to maintain the programmed coolant temperature. Benefits are reduced noise and increased fan reliability.
post #6 of 33 (permalink) Old Oct 9th, 17, 06:36 PM
Vega$69's Avatar
Interesting for sure. Similar to the PWM fuel pump set ups.
DT likes this.
Vega$69 is offline
post #7 of 33 (permalink) Old Oct 10th, 17, 10:39 PM
I used the Derale PWM Controller P/N 16795 for the LS3/480 I put in my 55 BelAir as I wanted to avoid the noisy full on/off only feature that the ECM has. I'll say I was suspicious off it's reliability and left the ECM fan control as a backup. Well, this past summer we drove the car from SoCal to Maine and back, nearly 7500 miles through hot weather and lots of rain and the controller worked flawlessly.
BrewHog55 is offline
post #8 of 33 (permalink) Old Oct 11th, 17, 04:00 AM Thread Starter
DT
Donny
DT's Avatar
This is the kind of information I was looking for. I have read many negative reviews. Many guys using aluminum radiators had problems. Are you using an aluminum radiator?? Thx
DT is offline
post #9 of 33 (permalink) Old Oct 11th, 17, 04:35 AM
Bruce
I have used old school set up, copper/brass radiator and clutch fan with stock fan shroud on SB and BB and never had issues on more than a dozen first gens. . . .JMO
The Camaro Guy is online now
post #10 of 33 (permalink) Old Oct 11th, 17, 04:41 AM
Vega$69's Avatar
He has an LS and needs electric fans.
DT likes this.
Vega$69 is offline
post #11 of 33 (permalink) Old Oct 11th, 17, 11:34 AM
I have a Griffin aluminum radiator along with a single Spal electric fan.
The setup keeps everything nice even with A/C
DT likes this.
post #12 of 33 (permalink) Old Oct 11th, 17, 11:46 AM
My 68 Camaro has healthy 383/5speed with an aluminum radiator with a 7 blade clutch fan. This setup works very nice as well, even with A/C. Never gets over 180-190. Went with the aluminum radiator a few years ago since it's getting harder to find a good old school radiator guy.
With the LS you don't have the option for a fan/clutch setup, which I prefer.
The thing with electric fans that I hate is how loud they get when full on. Having a PWM controller the fan has never come on full speed and yet the temps remain in range.
When ya cruise into the parking spot, ya want to only hear that nice sweet sound of the motor:-)
DT likes this.
post #13 of 33 (permalink) Old Oct 11th, 17, 01:06 PM Thread Starter
DT
Donny
DT's Avatar
Very nice to hear Don, this sounds promising.
DT is offline
post #14 of 33 (permalink) Old Oct 11th, 17, 01:07 PM Thread Starter
DT
Donny
DT's Avatar
Exactly what I want!!
DT is offline
post #15 of 33 (permalink) Old Oct 11th, 17, 01:09 PM Thread Starter
DT
Donny
DT's Avatar
Yes I have the old school set-up on my SS396. Works great. The LS3 set-up gets electric fans. I'm looking for a good PWM controller.
DT is offline
