Electric fan controller... - Team Camaro Tech
 5Likes
post #1 of 16 (permalink) Old Oct 21st, 17, 01:16 PM Thread Starter
So, on recommendation of a controller, and after some searching, I found this to fit the bill for me. $66 off ebay.
I also have an electric water pump now...no more belt throwing at 7500+
I could have used this to run the water pump and 1 fan, OR 2 fans....I'm driving 2 fans.(35GPM water pump runs constant)
All hooked up today...sat in the driveway for 30-45 minutes, at idle, and never went over the set point (set 15* lower than temp wanted due to probe in fins)....time to hammer on her a little. Took a spirited drive....worked flawlessly....never seen 180* (T-stat was set for 165)
Davies Craig Digital Thermaticģ Fan Switch (12V & 24V) (0444)
69X66 likes this.
68 Camaro~LSx ~all motor
post #2 of 16 (permalink) Old Oct 21st, 17, 03:03 PM
DT
Donny
DT's Avatar
Wow can't beat that price Doug. Looks good too!!
DT is offline
post #3 of 16 (permalink) Old Oct 21st, 17, 03:12 PM Thread Starter
Re: Electric fan controller...
Thanks. Was trying to do it on the cheap in case it didn't work....they have some nicer ones too....remote water pumps too.
Davies Craig Switches & Digital Controllers - Electric Water Pumps & Electric Fans
post #4 of 16 (permalink) Old Oct 21st, 17, 03:44 PM
Nice set-up, nice job.
post #5 of 16 (permalink) Old Oct 21st, 17, 06:36 PM
Matthew
I have used several. I prefer the sensor in the head.
$14 on ebay.
windsma is offline
post #6 of 16 (permalink) Old Oct 21st, 17, 07:56 PM
DT
Donny
DT's Avatar
I really like the 10 second feature which triggers the 2nd fan.
DT is offline
post #7 of 16 (permalink) Old Oct 22nd, 17, 03:04 AM Thread Starter
$14 on ebay.
That will be coming now that I know it works well.
Yes, helps with power surge
I'll have to get it on video sometime
post #8 of 16 (permalink) Old Oct 22nd, 17, 03:43 AM
George
Gbauer's Avatar
When I went electric I used a fin probe as well. Temp sensor stayed in the head. Temp never went above the probe temp. It was pretty darn accurate.
I had the fin probe located about halfway down just below the inlet. My thought was I'd always have water there and it was the hottest aread.
Sold:
Offy intake
Holley 390 CFM carb
Mild cam
Custom interior
Gbauer is offline
post #9 of 16 (permalink) Old Oct 22nd, 17, 06:51 AM Thread Starter
Fin probe in the lower left (Driver side) and set at 165, which in the directions said approx. 15* difference.
So, at 165 on the controller the fans come on, but the T-stat is reading 155-160 or so.
After driving around some and gettin' on it a little 170-175ish was tops....which I like.
They do have an adapter to put the probe in the coolant...just not sure where/if I want to do it....yet.
post #10 of 16 (permalink) Old Oct 23rd, 17, 03:49 PM
But...but...but...
Everyone knows that's impossible!...you can't cool a Camaro with anything but the mechanical clutch fan
Sorry folks, couldn't resist.
68rs406 and wireboy355 like this.
Hanging on the Maine Coast...moved back North
1969 RS/SS, 383, 4spd, 373s, 12bolt, FatMat, Vintage Air - Super Red, and it's my first Camaro.
Engine pics
Radiator pics
Build album
Lobstah is offline
post #11 of 16 (permalink) Old Oct 24th, 17, 04:56 AM Thread Starter
Originally Posted by Lobstah View Post
But...but...but...
Its probably because I have a 3-core aluminum radiator, and a LS motor in it that it works
H20cooled and wireboy355 like this.
post #12 of 16 (permalink) Old Jan 7th, 18, 05:19 AM
Will be wiring my fans in the next week or two...we'll see how well they cool down my little stroker
Engine pics
Radiator pics
Build album
Lobstah is offline
post #13 of 16 (permalink) Old Jan 7th, 18, 05:28 AM
George
Gbauer's Avatar
$14 on ebay.
Couldn't keep it working for my L6. 2 failed on me. The radiator version, however, worked perfectly. Never failed.
I was even using late model OEM sensors...
Sold:
Offy intake
Holley 390 CFM carb
Mild cam
Custom interior
Gbauer is offline
post #14 of 16 (permalink) Old Jan 22nd, 18, 05:37 PM
Sean
Thatís a pretty clean set up. I donít recall seeing those when I was doing mine. I used the Volvo relay/BMW dual temp sensor as detailed by Onovakind. I love it, something for folks to consider. I always used a fin probe but the accuracy was suspect, the in manifold sensor is dead nuts. The fin probe worked great just not very finite.
The Volvo set up Keeps my antiquated junk cool...
How do you run the electric pump?
By the way I see you finally reached your goal of 10ís, nice work.
Sean
Franklin D. Roosevelt
68rs406 is offline
post #15 of 16 (permalink) Old Jan 22nd, 18, 06:58 PM Thread Starter
Thank you, been a loooooonnnnnggggg road to see 10's
As for the WP, it's running full time as a mechanical one would.....for now.
