Big Block Aluminum Radiator Hose Numbers Please - Team Camaro Tech
post #1 of 5 (permalink) Old Nov 4th, 17, 06:10 PM Thread Starter
Mickey
Moonpie's Avatar
Buying a Be Cool 10168 radiator soon for my big block.
Can anyone pass along upper and lower radiator hose part numbers please?
Inlet size is 1 1/2
Outlet is 1 3/4
The outlet could be a pain as the inlet to the water pump is 2 inches. (why did they have to do that)
Thanks.
Moonpie is offline
post #2 of 5 (permalink) Old Nov 4th, 17, 07:25 PM
Re: Big Block Aluminum Radiator Hose Numbers Please
Your mileage may vary.....do your homework
Bottom Gates 21034
Top straightish Gates 20607
Top, if you need an s-bend Gates 20827
rodent4 is offline
post #3 of 5 (permalink) Old Nov 5th, 17, 04:59 AM Thread Starter
Mickey
Moonpie's Avatar
Bottom Gates 21034
Thank you man, will look into them for sure.
Moonpie is offline
post #4 of 5 (permalink) Old Nov 6th, 17, 03:22 AM
Greg
pittpens24's Avatar
Take all your measurement with you and the #'s above to your local Napa. They have everything and most likely in stock. I did have to order a hose for the bottom because of the big end on the water pump tho.
'68 Camaro with RS conversion
Moser 9" with 4:11
Tremec T-56 Magnum 6 speed
572 BB - CM Engines
pittpens24 is offline
post #5 of 5 (permalink) Old Nov 6th, 17, 05:12 AM
Inlet size is 1 1/2
Outlet is 1 3/4
Thanks.
That's the radiator I run in my 69. I just used the factory repro hoses. They fit perfectly.
'69 SS396 X66 L34 08D M21 BS
460ci Gen VI 9.75:1 AED 950 carb
Semper Fi!
HawkX66 is offline
