Cold to 240 in 3 mins? - Team Camaro Tech
 3Likes
post #1 of 19 (permalink) Old Nov 14th, 17, 04:04 PM Thread Starter
david
Send a message via AIM to kabinet Send a message via MSN to kabinet
I'm building a car with an LS3 480. How long should it take to get hot? I'm not driving it but just running it in the driveway every week or so and it gets hot fast. I'll time it next time but in 2-3 mins it hits 240 degrees before I get scared and turn it off. I have an autorad radiator and an electric fan that kicks on. I've opened the cap while its running and the coolant is still. Should I see it flowing? The upper hose is warm and the lower is cold. I'm worried that maybe there is a blockage or the waterpump isn't working. What should I do? Thanks!
kabinet is offline
post #2 of 19 (permalink) Old Nov 14th, 17, 04:51 PM
Re: Cold to 240 in 3 mins?
You may have an air lock. Google LS air lock for all you will ever want to know and then some...
1959 El Camino project
1957 Buick Caballero project
dhutton is online now
post #3 of 19 (permalink) Old Nov 14th, 17, 05:05 PM
scblucam's Avatar
Test your thermostat in a pot of boiling water. Does it open? Sounds like not.
68 302 M20 - 85 IROC Z
scblucam is offline
post #4 of 19 (permalink) Old Nov 14th, 17, 05:54 PM
kevin
water pump rotation correct?
flat tire is online now
post #5 of 19 (permalink) Old Nov 14th, 17, 06:17 PM Thread Starter
david
That's one thing I was worried about. With my belt setup its rotating opposite of the harmonic balancer.
kabinet is offline
post #6 of 19 (permalink) Old Nov 14th, 17, 06:26 PM
Only one direction water pumps for LS engines as far as I know.
post #7 of 19 (permalink) Old Nov 14th, 17, 06:31 PM
Pretty sure I have never seen an LS accessory drive that does not rotate the water pump in that direction.
Bleed the air out of your cooling system. This is a very common problem...
post #8 of 19 (permalink) Old Nov 15th, 17, 01:04 AM Thread Starter
david
Thanks Don. I googled air lock and bleeding the system and the consensus seems to be that if I don't have a bleeder valve I just run the engine with the radiator cap off to let the air escape while parked up an incline. I'll do that tomorrow. I have the steam vents attached to the radiator. Are they supposed to get the air out of the system?
kabinet is offline
post #9 of 19 (permalink) Old Nov 15th, 17, 04:16 AM
Chris
130fe's Avatar
Fill the engine with coolant from the top hose. Worst come to worse, other guys have raised the rear of the car to help get rid of the air bubble. Works every time.
Chris
1968 Camaro SS coupe, Lemans Blue/medium blue interior
LS3/T56 Ridetech Suspension
130fe is offline
post #10 of 19 (permalink) Old Nov 15th, 17, 05:38 AM
Hmm, I thought you raise the front of the car.
post #11 of 19 (permalink) Old Nov 15th, 17, 05:42 AM
Greg
Take the upper radiator hose off and fill through that. Fill it slow and let it leak the air out. When you start it run it with your radiator cap off and heater set to hot so you have water flowing through your heater core. I had issues with mine until I ran it that way for about 10-15 minutes and then it was fine.
My 69 Build thread :
1995 Z28 (sold)
1987 Iroc-Z (sold)
2005 350Z (sold)
gphusker is offline
post #12 of 19 (permalink) Old Nov 15th, 17, 06:04 AM
Vega$69's Avatar
The T-stat it at the lower hose so it will not let water into the block until it opens.
It will not open until water is at the T-stat so filling thru the top hose will help to accomplish getting coolant into the engine.
The WP can not pump air. So again if the radiator is filled thru the cap there is no coolant in the block for the WP to pump.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #13 of 19 (permalink) Old Nov 15th, 17, 10:37 AM
Matt
What type of temperature gauge are you using? Is it accurate?
12 Bolt 3.55 Posi
461 BBC TKO600
Matt 69 is offline
post #14 of 19 (permalink) Old Nov 15th, 17, 05:36 PM
Bill
I've read a lot about air lock but never experienced it myself.
I'd remove the thermostat completely and re-assemble. Fire it back up and see if you see the water flowing.
arocars is offline
post #15 of 19 (permalink) Old Nov 16th, 17, 03:20 AM
Greg
pittpens24's Avatar
That seems to be heating up awfully fast. I have a 572 BB and had some issues with my elec fan turning on. Even when it didn't turn on at all, I was able to run a good 10 plus minutes before I got scared and killed it. I am with John, sounds like you have no coolant in your block!
'68 Camaro with RS conversion
Moser 9" with 4:11
Tremec T-56 Magnum 6 speed
572 BB - CM Engines
pittpens24 is online now
