67 Dash Ducting - Team Camaro Tech
post #1 of 8 (permalink) Old Nov 19th, 17, 09:21 AM Thread Starter
Apprentice
Pat
67 Dash Ducting
I've been looking around for this info and haven't been able to find it... someone just post a link if I'm being an idiot and it's easily available. I have what I believe to be the complete set of ducts but I'm looking for a reference on installing them. My car had a/c at one point but no longer does. I'd like to just get the heater set up at least so I can run the defroster and keep driving it. The only part I know Im missing is a thermostat but I figured I would just wire in a switch on a plate in the dash for now and worry about that later.
Any help would be greatly appreciated
p12nash is offline
post #2 of 8 (permalink) Old Nov 19th, 17, 10:43 AM
jerry
Re: 67 Dash Ducting
67 heater ducts
jerry67 is online now
post #3 of 8 (permalink) Old Nov 19th, 17, 12:17 PM Thread Starter
Apprentice
Pat
Re: 67 Dash Ducting
Awesome! Thanks so much, I really appreciate it
p12nash is offline
post #4 of 8 (permalink) Old Nov 19th, 17, 01:46 PM
Larry
Re: 67 Dash Ducting
I just installed an entire factory heater system in my 67.
The only duct you will have is for the defroster. At the (center) end of the heater case there is a small deflector to split air downward.
That's it for ducts.
Also, there is no "thermostat". Just a fan *on/off/speed* switch and a resistor to make the fan speeds work.
I can't complain, but sometimes I still do.
Larry Madsen is offline
post #5 of 8 (permalink) Old Nov 20th, 17, 07:40 AM Thread Starter
Apprentice
Pat
Re: 67 Dash Ducting
I have all dash vents and I believe all of the ducting that goes along with them however the louver doors or gates or whatever they are called that connect to the "thermostat" I was describing (hvac control interface) are all damaged and so is the controller. Will this be an issue setting up the defroster again? I'm only going to have 4 days to work on the car over thanksgiving and dont have access to it until then so Im just trying to plan ahead as much as possible
p12nash is offline
post #6 of 8 (permalink) Old Nov 20th, 17, 08:56 AM
jerry
Re: 67 Dash Ducting
Are you saying you are going to use all the a/c duct work and dash vents, a 67 without a/c originally didn't have dash vents
post #7 of 8 (permalink) Old Nov 20th, 17, 11:17 AM
Michael
Re: 67 Dash Ducting
If you have the 1967 AIM, just look at the C60 section.
Also, there is no "AC" thermostat, just the one for the engine.
mahunt is offline
post #8 of 8 (permalink) Old Nov 20th, 17, 05:55 PM Thread Starter
Apprentice
Pat
Re: 67 Dash Ducting
At some point a previous owner put in ac and dash vents. The ac was later removed but the dash vents remain (with no ducting attached), I'm assuming when a larger radiator and separate transmission cooler were installed. I eventually will put in a vintage air system but as I have limited time and it's almost December for now I think just getting the defroster back up and running should be plenty.
p12nash is offline
