LS Swap vintage air install - Team Camaro Tech
 4Likes
  • 1 Post By workng247
  • 1 Post By dhutton
  • 1 Post By Vega
post #1 of 7 (permalink) Old Nov 25th, 17, 01:21 PM Thread Starter
DT
Donny
DT's Avatar
Hey guys, I just mounted the condenser to my Vintage Air system. I have a few questions. The suction side from the compressor (#10) to bulkhead in firewall gets a service port correct ?? Any other service ports needed ?? The discharge (#8) side from compressor goes to the condenser. The #6 from the drier (liquid line) goes to the #6 in the firewall. Does this #6 liquid line have to be a tube ?? Thx!
DT is offline
post #2 of 7 (permalink) Old Nov 25th, 17, 02:30 PM
Jeff
Re: LS Swap vintage air install
Hey Donny, I got your PM. You are right I ordered an extra piece of straight tube that I bent to fit,
I think you want to have a service port somewhere in the high side as well so you can see what your pressures are with the gauges.
ID:	197682   Click image for larger version
ID:	197690   Click image for larger version
DT likes this.
And this too shall pass.
69 X11 SS, Glacier Blue, LS3 480, T56 Mag, Lots of stuff done to it, all by yours truly
Build thread:
workng247 is offline
post #3 of 7 (permalink) Old Nov 25th, 17, 02:40 PM
Jeff
I don't think the liquid line has to be rigid but since its not connected to anything that moves it doesn't have to flex.
My high side service port is at the compressor.
DT likes this.
Build thread:
post #4 of 7 (permalink) Old Nov 25th, 17, 02:50 PM
You need two service ports. One on each side of the compressor or on the lines connected to them. They should come with the kit.
Liquid line can be flexible hose.
DT likes this.
1959 El Camino project
1957 Buick Caballero project
dhutton is offline
post #5 of 7 (permalink) Old Nov 25th, 17, 03:54 PM Thread Starter
DT
Donny
DT's Avatar
Thank you very much guys!!
DT is offline
post #6 of 7 (permalink) Old Nov 25th, 17, 06:50 PM
Vega$69's Avatar
You can run all flexible lines if it works better for you.
X2 on the service ports
DT likes this.
Vega$69 is offline
post #7 of 7 (permalink) Old Nov 28th, 17, 02:46 PM Thread Starter
DT
Donny
DT's Avatar
Hey Jeff, I just noticed your heater control valve on the inner fender. I believe the servo motor must face down. That would put the black wire connection on the inside towards the engine, not towards the fender. I have heard VA having problems with these heater control valves and I'm not sure this has anything to do with it, but I thought I mention it. Thanks for your help!
DT is offline
