Need to replace the Heater Core - Team Camaro Tech
 5Likes
  • 4 Post By Everett#2390
  • 1 Post By Everett#2390
post #1 of 12 (permalink) Old Feb 17th, 18, 01:27 PM Thread Starter
I have a 1968 non/AC. The Heater core went bad yesterday..... Antifreeze everywhere.... Inside and outside the car.
I see there are numerous sizes that all apparently fit the car. Does anyone have any first hand knowledge on the correct size. I haven't taken the old one out yet.
That brings me to the second question...how difficult is this? Thanks much for the help.
dukhnt is offline
post #2 of 12 (permalink) Old Feb 17th, 18, 02:29 PM
Andrew
Andrew69's Avatar
Re: Need to replace the Heater Core
Go ahead and resign yourself to remove the passenger fender to access the under hood heater box. Then it becomes much easier.
Skunk Works
Some photos:
Member # 159
Andrew69 is online now
post #3 of 12 (permalink) Old Feb 17th, 18, 03:22 PM
Chick
68camaroz28's Avatar
What I think your first concern or question should be is how to get it out. Many have to remove the fender which is a real pain not to do any paint damage and line up. I've had a couple experts tell me they can get one out without removing the fender but again, its a huge pain. Work on the plan to remove first and know absolutely what parts you will need before buying is a good rule of thumb. When you obtain your new heater core, take it to a radiator shop and have them do a pressure check to make sure your OK.
Chick
68, 69, & 2015 Z/28's
69 Nova's L34 Father/Son & L78 Surv purch-new
67, 68, & 2015 Z06 Corvettes
Our 68Z Restoration
68camaroz28 is offline
post #4 of 12 (permalink) Old Feb 17th, 18, 04:11 PM
Hmm, I've changed out a few from inside.
Drain coolant when disconnecting core hoses into drain pan outside firewall.
Push pass seat back as far as it will go.
Lay down a continuous sheet of plastic from trans tunnel to seat to toe panel at the top and over the rocker.
Unplug the resistor block above /behind the glovebox.
Remove the hoses and five speed nuts seen.
Inside wioth hands, pry out heater box - knida hard sincve you are working against the caulking and SLIGHTLY bent core nipples on engine side.
Once box loose from wall, lay with core facing up on floor.
Remove core and fix original core.
Assembly is reverse except install new clay weatherstripping on box for a good seal between box and firewall.
You should use a dab apiece of petroleum jelly on the core hoses, even if new, not a bad idea, when sliding on hoses.
Add coolant and more to fill core.
All done without removing anything other than resistor block plug.
The above works IF nipples are OE bent from OE core, If nipples bent more parallel to firewall, then it will be difficult tin removing box from firewall.
Rarerat, rogerh, Niblet and 1 others like this.
Everett#2390 is online now
post #5 of 12 (permalink) Old Feb 17th, 18, 05:29 PM
Nick
Rarerat's Avatar
I agree, I have changed many this way over the years.
Rarerat is offline
post #6 of 12 (permalink) Old Feb 17th, 18, 05:54 PM
Chris
ckaram's Avatar
My recommendation is have your original one re-cored. That way you know it will fit.
I did the replacement myself about 10 years ago and I am no mechanic. 68, non-air car and did not have to remove the fender. Listen to guidance above. Also, if interior box looks tired now's the time to repaint and dress it up. Winter's the best time to do the work...doesn't cut into summer drive time while it's down
Check my rides:
1968 Camaro Convertible LS1, T56
2016 Challenger RT Scat Pack Shaker
ckaram is offline
post #7 of 12 (permalink) Old Feb 18th, 18, 03:52 PM Thread Starter
Thanks for all the help and suggestions. Much appreciated.
dukhnt is offline
post #8 of 12 (permalink) Old Feb 19th, 18, 09:22 AM
Maybe I should correct spelling and make this a sticky?
rp930 likes this.
post #9 of 12 (permalink) Old Feb 19th, 18, 09:38 AM
Vega$69's Avatar
You donít need to remove the fender to remove the heater core. Simple to pull it from the inside.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #10 of 12 (permalink) Old Feb 19th, 18, 09:40 AM
Andrew
Andrew69's Avatar
Stick it Everett.
I too learned something during this discussion. The only thing I can add is if I were accessing it from inside the cabin I would remove the passenger seat.
Skunk Works
Some photos:
Member # 159
post #11 of 12 (permalink) Old Feb 19th, 18, 09:48 AM
Vega$69's Avatar
Originally Posted by Andrew69 View Post
Stick it Everett.
And the glove box
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #12 of 12 (permalink) Old Feb 19th, 18, 01:34 PM
Larry
Removing the glove box not only gives you more room to work, but gives much better access and vision into the area.
You might also note the three control cables ... which may or may not be a problem, but will need to be contended with and managed in the process. One or more could be removed from the box if it becomes necessary.
Just realize they are there and on a 50 year old car could be crossed up with who knows what.
Another cautionary note might be that if they have console gauges there is an oil line running in the area and if it's an old plastic line it could be brittle (and even if not) you don't want to stress it into a break.
I can't complain, but sometimes I still do.
Larry Madsen is offline
