Driver side kick panel vent - Team Camaro Tech
post #1 of 7 (permalink) Old Feb 23rd, 18, 05:11 AM Thread Starter
Probationer
Hello. I have a 67 Camaro and the driver side kick panel does not have a vent. I have read where A/C Camaros do not have driver side vents. Mine does not have A/C but I don't know if it did originally. My question is: Is the venting there so I can install a Kick Panel with a vent or is it made with No venting capability.
thanks, John
John_D is offline
post #2 of 7 (permalink) Old Feb 23rd, 18, 08:08 AM
Kevin
KevinW's Avatar
Re: Driver side kick panel vent
The AC option just uses a separate plate to block off the hole in the metal structure, then a blank kick panel is used on the driver side. On the pass side the vent hole is used with the MAX AIR setting vent.
Just replace blank plastic kick panel, with one that has the vent, should fit fine.
Kevin
KevinW is offline
post #3 of 7 (permalink) Old Feb 23rd, 18, 09:35 AM
I have a 67 A/C car. There is no block off plate. The kick has the same back construction as any other.
Call for restoration and custom paint scheduling:
Sauron67MM is offline
post #4 of 7 (permalink) Old Feb 23rd, 18, 11:50 AM
Roger
rogerh's Avatar
Scott you mean, there is no block off panel behind the plastic kickpanel. Don't you?
Roger
rogerh is offline
post #5 of 7 (permalink) Old Feb 23rd, 18, 11:57 AM Thread Starter
Probationer
Thanks. That's what I needed to here. The other problem I have now is the A/C vents in the dash are there and have no function as I am not planning on converting to A/C. There are no holes in the firewall for vents and there is no center dash vent at all. I think the guy before me removed the vertical A/C box and replaced it with a horizontal heater box. I don't plan on touring, just cruising locally and dragging. It's a big block and not a lot of room. I may just leave the dash vents in or remove and cover the holes. I wish people would leave original stuff like it was. At least I have myself a sweet Camaro. Live to drive and drive to live. Peace.
John_D is offline
post #6 of 7 (permalink) Old Feb 23rd, 18, 12:12 PM
Kevin
KevinW's Avatar
Hmm, I guess I was thinking of something else. So I guess there was a big glob of dum-dum sealing the the plastic to the metal, sealing the vent, right?
Kevin
KevinW is offline
post #7 of 7 (permalink) Old Feb 23rd, 18, 05:18 PM
Yes. I stock blocks of duct sealant. Easily obtained at local hardware or professional stores.
