69 astro vent cable mount? - Team Camaro Tech
post #1 of 5 (permalink) Old Mar 2nd, 18, 11:47 AM Thread Starter
Probationer
Andrew
We are working on a 69 camaro RS/SS that was purchased from Barrett Jackson, with many loose ends.. Vents were stuck open, found kick panels to be glued and cable sheathing broken. Ordered aftermarket kick panels and need help with where the factory mounted/secured the dash vent cable. Our kick panels cable sheathing in loose at the start of the cable. We will be securing the sheathing to fix this but we are having issues where the cable routes to the dash vent. Trying to open/close the vent the cable moves around causing the vent to not move very much. Does the factory have a clamp that goes over the cable and bolts to the firewall/cowl to prevent this? Cannot find traces of where the cable would have been previously secured, the dash/windshield base was been previously cut and welded due to rust. Cannot find anything in the manual, google, youtube, or on here. Any help is appreciated, thanks.
FishersAuto is offline
post #2 of 5 (permalink) Old Mar 2nd, 18, 12:13 PM
keith
X-77 keith's Avatar
The new kick panels should come with new cables. And yes the factory did have a bracket just above the emergency brake that had a small "U" type clamp held with a sheet metal screw that kept the cable in place. The kick panel does need the as you called it glue to seal the hole in the cowl from leaking rain water in the car. I use seam sealer, others use strip calk or dum dum. It will all work.
X-77 keith
X-77 keith is offline
post #3 of 5 (permalink) Old Mar 8th, 20, 03:07 PM
Probationer
Greg
Re: 69 astro vent cable mount?
Iím missing the clamp as well. Any idea who sells the clamp? In regards to sealing the kick panel, do you only need to seal around the vent hole?
jg1969 is offline
post #4 of 5 (permalink) Old Mar 8th, 20, 04:15 PM
Rob
rlw68's Avatar
I just finished removing the interior of my '69. Here's a picture of the clamp.
Rob
1969 Camaro Z/28. Norwood 02D. Lemans Blue
rlw68 is offline
post #5 of 5 (permalink) Old Mar 8th, 20, 05:36 PM
Probationer
Greg
Thanks Rob! Really helps to know what Iím looking for.
jg1969 is offline
