BBC Fan Shroud Help - Team Camaro Tech
 2Likes
  • 1 Post By Mike_S
  • 1 Post By Brettallen59
post #1 of 13 (permalink) Old May 10th, 18, 04:05 PM Thread Starter
Brett
BBC Fan Shroud Help
I purchased a fan shroud from Eckler's on Sunday. The moment I received the order confirmation showing it was for a 67-68 I shot off an email telling them I wanted a fan shroud for a 69. They did not read the email until Monday afternoon, but they sent me shipping notification on Sunday that it had shipped!
Can anyone help by letting me know (Before I open the box) if the fan shroud for a 67-68 BB is different and how it is different? If it's just not going to match up, I'll send it back and get the correct shroud. Part number that I received: 33-179739-1. Part number that Eckler's said is the one I would get for a 69: 33-379383
Thanks!
Brett.......
Rockets Up In 2020!
Brettallen59 is offline
post #2 of 13 (permalink) Old May 10th, 18, 04:18 PM
Re: BBC Fan Shroud Help
Shroud will be deeper on '67-'68 (long water pump) than a '69 with short water pump.
post #3 of 13 (permalink) Old May 10th, 18, 04:26 PM Thread Starter
Brett
I have a long water pump on my 396...
Rockets Up In 2020!
post #4 of 13 (permalink) Old May 10th, 18, 04:28 PM
kevin
I went to jegs to look and there is a listing for 67-8 and a listing for 69. also difference in price
they look different to me
flat tire is offline
post #5 of 13 (permalink) Old May 10th, 18, 04:39 PM Thread Starter
Brett
So it sounds like I do not have the correct water pump for a 69. Wonder if, since I have it all apart installing a new cam, if I should break down and put a short W/P on it and get the correct shroud. My fan is pretty close to the fan (approx. 1/2"), but it clears without concern. Something to contemplate......
Thanks Everett & Kevin!
Brett......
Rockets Up In 2020!
post #6 of 13 (permalink) Old May 10th, 18, 05:01 PM
kevin
if you change pumps will your pulleys align up?
post #7 of 13 (permalink) Old May 10th, 18, 05:38 PM
The difference in the two shouds is to match the difference in the length of the two water pumps. You have a '69 water pump on your '69 Camaro so if that is a "69 shroud it should fit (having the fan half in half out of the shroud to maximize air flow). If the one you ordered was for a 1967-'68 it will bolt up, but your fan blades will be too far into the shroud for it to work efficiently.
Big Dave
Larger Dave is online now
post #8 of 13 (permalink) Old May 10th, 18, 07:04 PM
jim
I have a OEM BigBlock fan shroud for a 69 Camaro which uses the correct long water pump No issues PM for a price if interested.
262jp is offline
post #9 of 13 (permalink) Old May 10th, 18, 07:30 PM
Michael
1967 & 68 BBC used the short water pump. The 69 uses the long water pump.
Both my 67's (w/short pumps) have the blades about 1/2 the thickness of the blade pitch into into the shroud edge area.
I would think that a '67/68 shroud would allow the blades to be too deep into the shroud with a long pump.
HawkX66 likes this.
67 LOS SS/RS L35 Hardtop - Original w/UOIT
67 NOR SS/RS L35 Convertible - Restored
Mike_S is offline
post #10 of 13 (permalink) Old May 11th, 18, 05:40 AM
69 big blocks ran long water pumps (811) like Michael mentioned. I would refuse the shipment and get the correct 69 shroud.
Mine with my born with shroud:
'69 SS396 X66 L34 08D M21 BS
460ci Gen VI 9.75:1 AED 950 carb
Semper Fi!
HawkX66 is offline
post #11 of 13 (permalink) Old May 13th, 18, 03:32 AM Thread Starter
Brett
Dave,
Yes, I sent the wrong one back and will order the correct shroud. Thanks for the pics. I notice that I have the same fuel filter with return line on my engine, but my filter actually comes up on the other side (passenger) of the engine. I think when I bought mine, it was for a Vette. Could that be why? Also, I LOVE your valve covers! I found some as well. Actually are dated pretty old because on the inside it does not reference 454. They just say; Chevrolet 396-427 3276396. Only one dripper is broke.....
Brett.....
HawkX66 likes this.
Rockets Up In 2020!
post #12 of 13 (permalink) Old May 13th, 18, 08:45 AM
Originally Posted by Brettallen59 View Post
Dave,
Brett.....
Brett...
Just saw this, may be a bit late but here's my setup. BBC 4-core radiator, Long Water Pump, and yeah... 454. Don't know how much will change when I install the VA Compressor, but of course the pulleys will. If you want me to measure anything, give me a shout.
'69 LeMans Blue Coupe, White Interior, 030" over 454, Super T10 4-Speed, Holley 4150, Pertronix Ignition
CompCams XS274S, 781 Oval Port Heads, PYPES Full 3" SS Exhaust, Hooker Comp Headers, Wilwood Calipers/MC
JGC Steering Box, Helix Uppers/Lowers, ProForged BJs, SpeedHut Gauges, MOMO Steering Wheel, Budnik 17" Wheels
57vette is offline
post #13 of 13 (permalink) Old May 14th, 18, 05:37 AM
Dave,
Brett.....
Thanks Brett. I love my M/T covers too. I have three sets lol. My first set is my old set like you bought. I didn't want to mess with those so I bought another set to cut the drippers off to clear my roller rockers. I still need to polish them up a little, but I like the more dull aluminum look versus the shiny polish.
My filter is in the stock location in that pic, so if yours was for a Vette, that would make sense. Unfortunately I had to eliminate mine because I went with an electric pump.
Semper Fi!
HawkX66 is offline
