Overflow tank for ‘69 RS? - Team Camaro Tech
 7Likes
  • 1 Post By dhutton
  • 1 Post By Vega
  • 1 Post By X-77 keith
  • 1 Post By Chevy68
  • 1 Post By The Camaro Guy
  • 1 Post By 57vette
post #1 of 12 (permalink) Old May 31st, 18, 08:26 AM Thread Starter
Just curious what others have used, I’m going to start messing with my RS grill conversion and also the Vintage Air install. I figure a puke tank is a good idea for a BBC that doesn’t like traffic and I occasionally see temps at 210-220 degrees.
I remember Timmy put some kind of Nova or Chevy II tank in his car but forget whether he’s dealing with hideaway headlights.
'69 LeMans Blue Coupe, White Interior, 030" over 454, Super T10 4-Speed, Holley 4150, Pertronix Ignition
CompCams XS274S, 781 Oval Port Heads, PYPES Full 3" SS Exhaust, Hooker Comp Headers, Wilwood Calipers/MC
JGC Steering Box, Helix Uppers/Lowers, ProForged BJs, SpeedHut Gauges, MOMO Steering Wheel, Budnik 17" Wheels
57vette is offline
post #2 of 12 (permalink) Old May 31st, 18, 08:41 AM
Re: Overflow tank for ‘69 RS?
Here is the Nova tank.
https://www.ebay.com/itm/OER-Radiato...IAAOSwX3FbA75n
57vette likes this.
1959 El Camino project
1957 Buick Caballero project
dhutton is online now
post #3 of 12 (permalink) Old May 31st, 18, 11:31 AM Thread Starter
Re: Overflow tank for 69 RS?
Originally Posted by dhutton View Post
Thanks Don... I think thats the one Timmy used. Its listed as a "Overflow" tank. Thats different than a "Recovery" tank, right? Recovery tanks need to be a little bigger? Also need a different cap, right?
Then there's a choice of caps:
Probably going to get laughed at, but OK... what are the Pros/Cons to a Overflow versus a Recovery tank setup and is it worthwhile to try to rig one on my car? IIRC, you'd have to eliminate the traditional radiator cap because that cap would go on the recovery container... I think. I know that in a recovery system the fluid could expand and go into the tank, and then the fluid will be drawn back into the system at some point. OTH, overflow tanks are just for puking fluid when things get too hot or there's too much pressure so it blows by the seal in the radiator cap and you have a puddle under the car?
Lately, on hot days and in heavy traffic, my car has puked about a cup of coolant after shutting it down and the temps have been 210-220. I'm going to take a look at the radiator cap, thermostat, probably the timing, and if all else fails... the water pump. Moving along at 65-70 on the highway, the temp drops back down to 180-190 which I figure is normal. But the puking is new, and nothing has changed as far as timing, carb, whatever.-Mike
57vette is offline
post #4 of 12 (permalink) Old May 31st, 18, 12:15 PM
Vega$69's Avatar
You may have too much coolant and the radiator is seeking its own level or may need a new 16# radiator cap
57vette likes this.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #5 of 12 (permalink) Old May 31st, 18, 12:20 PM
keith
X-77 keith's Avatar
John is right. The level should not be to the top. No drawbacks to having a recovery tank if seeing it does not bother you. You have to have one if you take it to a track. I have seen beer can overflow systems at the track. All of my big blocks ran a little warm in traffic and when not cruising.
57vette likes this.
X-77 keith
X-77 keith is offline
post #6 of 12 (permalink) Old May 31st, 18, 01:35 PM
Jeff
Installed Nova tank on my 68.
57vette likes this.
Thanks,
Jeff
1968 Camaro
Chevy68 is offline
post #7 of 12 (permalink) Old Jun 1st, 18, 04:48 AM
Bruce
If the system is working properly and a the radiator, fan, shroud, thermostat are good, it should not be necessary to have an overflow tank. These cars were not designed with this in mind. I currently have 3 BB's and have never had an overheating issue. My 69 C-10 tows a car trailer and with the AC blowing has never overheated. A built 427 with a 4 core copper radiator stock set up, as does the other 2 BB's.
57vette likes this.
The Camaro Guy is offline
post #8 of 12 (permalink) Old Jun 1st, 18, 05:01 AM
keith
X-77 keith's Avatar
Yes these cars were not designed with an overflow in mind. They were also not designed with today's demands and traffic in mind. It should not overheat. 200-220 in my mind is not overheating, but warm. The C-10 has a much larger radiator to displace the heat. My wrecker with a 454 dies not overheat with a copper radiator, but the radiator is a goliath compared to a first gen radiator.
57vette likes this.
X-77 keith
post #9 of 12 (permalink) Old Jun 1st, 18, 05:39 AM Thread Starter
Maybe John is right... I checked the cap and the seals don't look spectacular or fresh, actually a little chewed up and gummy in a bad way. On top of that it's a #15 cap and the engraved notations say "15 LB CLOSED SYSTEM" and "CHECK COOLANT LEVEL IN BOTTLE" so maybe this cap was borrowed from a system that actually had a separate coolant recovery bottle. Unless somebody switched caps on me at a show or cruise night (anythings possible) I never had this puking before.
Going to go out and pick up a fresh cap for starters, they are cheap enough. Anyone have any preference for the type with a red release lever as opposed to a plain cap? Probably a gimmick, but the Mr.Gasket unit with a built-in temperature gauge is intriguing.
I should note that I'm not seeing any steam or crap coming from the exhaust or engine, it's just from the overflow tube on the PS of the radiator. The radiator is a copper tank type, and I last filled it to about 2" from the cap neck.
DjD likes this.
57vette is offline
post #10 of 12 (permalink) Old Jun 1st, 18, 05:43 AM
Bill
I use the window wash tank as I never use it other wise .Not a lot of room under the hood
bills69 is online now
post #11 of 12 (permalink) Old Jun 1st, 18, 06:46 PM Thread Starter
Picked up a decent quality 16# cap this afternoon, thoroughly cleaned the radiator neck as it had a lot of rubberish residue where the old cap seated. Coolant is about 4" down from the top edge of the neck. Maybe the problem was the cap as the old one was cruddy. Check the comparison picture showing the new and the old below.
Now several guys running big blocks over in the FB page said they are running a Stant brand cap rated 26-32 PSI and have no problems with puking or overheating. Don't know if a different water pump figured into their situation. Anyway, AZ didn't have a Stant cap, so that'll have to wait.
57vette is offline
post #12 of 12 (permalink) Old Jun 3rd, 18, 08:23 PM Thread Starter
Update: Had a local show today and happy to say things seemed to have returned to normal. Temp never went above 180 this morning on the way over, and it did get fairly warm this afternoon... maybe 80-5 degrees. So on the way home I took a little joy ride to a local office park and took some pix while the car sat there for 15-20 minutes idling. I checked the temp every now and then and could actually see the gauge change when the thermostat opened and closed. Temp never went past 200, seemed to be cycling between 190-200 just sitting there. I then turned the engine off and watched underneath to see if she'd puke... nothing. So after around 5 minutes, I got in, started her up, temp showed 200 and by time I drove down the entrance about 1/8 mile... temp was dropping from 200 to 190, and 15 minutes later when I pulled in the garage it was between 175-180.
Don't know if the problem is 100% solved, I'll be watching everything carefully, but I'm hopeful that a $7.00 16# cap might've saved the day. While I did buy a new thermostat, the "old" one appears to be working just fine, so I'll stick with it for now.
57vette is offline
