Overheating with New Cap - Team Camaro Tech
 1Likes
post #1 of 16 (permalink) Old Jun 3rd, 18, 07:39 AM Thread Starter
Dan
Can someone tell me what’s up here?
Had an issue with the top radiator hose collapsing and fixed that with a new radiator cap! But now it overheats, what’s up with that?
Bad “new” cap?
69 LeMans Blue X77 Z28 (SOLD)
68 Corvette Bronze RS Z28
68 LeMans Blue SS 396 L78 (9978 orig miles)
DDZ28 is offline
post #2 of 16 (permalink) Old Jun 3rd, 18, 07:56 AM
Re: Overheating with New Cap
Originally Posted by DDZ28 View Post
Can someone tell me whatís up here?
Had an issue with the top radiator hose collapsing and fixed that with a new radiator cap! But now it overheats, whatís up with that?
Bad ďnewĒ cap?
Define overheats. Temperature goes too high or it pukes coolant.
1959 El Camino project
1957 Buick Caballero project
dhutton is online now
post #3 of 16 (permalink) Old Jun 3rd, 18, 08:24 AM Thread Starter
Dan
Bad “new” cap?
Both😡
DDZ28 is offline
post #4 of 16 (permalink) Old Jun 3rd, 18, 09:14 AM
Top hose is the return line and should be pressurized by the water pump. Since it is colapsing your pump is sucking but not getting anything through from the block.
I suspect that is due to a defective thermostat that is stuck closed. If the coolant is not circulating then I wouldn't be surprised if it is over heating.
Big Dave
Larger Dave is offline
post #5 of 16 (permalink) Old Jun 3rd, 18, 09:34 AM
Vega$69's Avatar
Big Dave
X2. Sucking from lower hose and not returnjng coolant to the radiator through the top hose will create negative pressure in the radiator and cause the hose to collapse.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #6 of 16 (permalink) Old Jun 3rd, 18, 09:56 AM Thread Starter
Dan
Big Dave
As mentioned I replaced the cap and the issue of the collapsing hose issue went away, now it overheats and pushed coolant out the overflow hose.
DDZ28 is offline
post #7 of 16 (permalink) Old Jun 3rd, 18, 10:20 AM
kevin
replace the thermostat !
flat tire is offline
post #8 of 16 (permalink) Old Jun 3rd, 18, 10:22 AM
Fred
77thor's Avatar
I don't see how changing out the radiator cap could effect a collapsing hose...?
As stated, I would start with a new thermostat (they're cheap).
Are both radiator caps rated at the same PSI?
77thor is offline
post #9 of 16 (permalink) Old Jun 3rd, 18, 10:52 AM Thread Starter
Dan
Old cap was 15# new one is 16#, I am in agreement to change the Thermostat.
Just looking for other input. Thanks
DDZ28 is offline
post #10 of 16 (permalink) Old Jun 3rd, 18, 11:06 AM
Was the hose collapsing while running or after stopping and cooled off?
post #11 of 16 (permalink) Old Jun 3rd, 18, 11:13 AM Thread Starter
Dan
After stoping and cooled off.
DDZ28 is offline
post #12 of 16 (permalink) Old Jun 3rd, 18, 01:36 PM
After stopping and cooled off.
If hose is collapsing AFTER cool off, then cap vent valve is not working.
Try old cap?
post #13 of 16 (permalink) Old Jun 3rd, 18, 01:53 PM
Cooled air in system created a vacuum. Your cap is not releasing vacuum for some reason.
post #14 of 16 (permalink) Old Jun 3rd, 18, 05:30 PM Thread Starter
Dan
I replaced the cap and the collapsing hose problem is gone but now it overheats!
DDZ28 is offline
post #15 of 16 (permalink) Old Jun 3rd, 18, 05:46 PM
Iím no expert but it seems that if the old cap was defective/stuck itís possible you were building higher than 16psi pressure preventing overheating and puking coolant. Iím sure one of the resident experts will weigh in soon.
What was the temperature with the old cap and the new cap?
