Thermostat drip - Team Camaro Tech
 2Likes
post #1 of 16 (permalink) Old Jun 28th, 18, 02:48 PM Thread Starter
keith
X-77 keith's Avatar
Thermostat drip
I have been working on cars for many years. That said I can not get my thermostat to stop dripping. I have removed it three times, and replaced the Felpro gasket three times. I did use a little smear of black RTV. Been doing the same practice for years with no come backs. All was cleaned and surface was smooth and flat.
I bought a Mr. Gasket reusable water outlet gasket #738G. I can't believe I paid $10.00 for it, but I'm going to try it. I'm also replacing my original water neck with a Dorman #902-2014.
I just want it to work, and don't plan to pull it off and on. I have a factory heat shield under my carb, so that makes this job a real pain. Anyone used this gasket?
X-77 keith
X-77 keith is offline
post #2 of 16 (permalink) Old Jun 28th, 18, 03:17 PM
Brad
Yes and they work great !!! At least for me !😬
69crush is offline
post #3 of 16 (permalink) Old Jun 28th, 18, 04:25 PM Thread Starter
keith
X-77 keith's Avatar
Thanks, that is what I wanted to hear.
X-77 keith
post #4 of 16 (permalink) Old Jun 28th, 18, 05:14 PM
Jeff
Re: Thermostat drip
Check your bolt lengths, I had one bolt that was about 1/16Ē too long and would bottom out.
Thanks,
Jeff
1968 Camaro
Chevy68 is offline
post #5 of 16 (permalink) Old Jun 28th, 18, 06:31 PM Thread Starter
keith
X-77 keith's Avatar
I tried the length. I ran it down without a washer first. Maybe the 1969 housing has a hairline crack. Dont know about that, but I do know I will be trashing it just in case.
X-77 keith
post #6 of 16 (permalink) Old Jun 29th, 18, 02:10 AM
R66
Ron
Re: Thermostat drip
The thermostat housing warps if over torqued. Lay a straight edge across the bottom from hole to hole to check it. I have used a wide file and then sand paper on a piece of glass to straighten the gasket surface on a housing I wanted to save due to numbers. Start with rough sand paper 80 or 100 grit and work down to 320 or 400 grit. Takes a while, but it will cure your leak. I can't remember exactly the grits I used.
I do the same thing on Holley base plates to save a carb.
Everett#2390 likes this.
R66 is offline
post #7 of 16 (permalink) Old Jun 29th, 18, 04:14 AM
Re: Thermostat drip
As Ron suggest, not only the housing, but also the manifold.
Yes, gasket is expensive, but works.
Yes, the process of the housing warping is called 'creep'.
Being torqued over time, read pressure from fastening, the housing bends.
Store windows are very well known for this.
Over time, the glass will 150% thicker at the bottom than the top, in twenty years.
1968RallySport likes this.
post #8 of 16 (permalink) Old Jun 29th, 18, 04:56 AM
kevin
Re: Thermostat drip
never heard that about glass
flat tire is online now
post #9 of 16 (permalink) Old Jun 29th, 18, 05:00 AM
Bill
Re: Thermostat drip
I had to replace the water neck this year because it leaked from the top not from the gasket or bolt area . Never have seen this before , fairly new ,not cracked very strange
bills69 is offline
post #10 of 16 (permalink) Old Jun 29th, 18, 08:33 AM
Re: Thermostat drip
Some file work on the manifold seating area or the housing may do the trick. When you file cover the are with machinist dye or black magic marker. file across the surface at an angle, one hand on each end of the file flat strokes, one file stroke right to left
and next left to right. when the dye is finally gone you should have a flat surface.
67 RS/SS 350, M21, 3:70 POSI, Hooker side mount headers, blue dot tail lights. owner since 1974.
327fuelinjected is offline
post #11 of 16 (permalink) Old Jun 29th, 18, 08:50 AM
Rob
satz28's Avatar
Re: Thermostat drip
I had great success with the Fel-pro molded rubber gasket that is similar to the Mr. gasket unit.
Rob
Sold 6-1-2014 after owning the car for 18+ years
69 Z-28 X-77 HO * DZ Put away * M20 * 4.10
406 CI * CC XR274R 236/[email protected] 564/570 110 LSA/106 ICL * Brodix IK 200
475 HP, 495# tor
Street Tires, Full Exhaust Sep 07 -12.68 @ 113 MPH * Street Tires, Open Headers Oct 08 - 12.65 @ 116.2 MPH
satz28 is offline
post #12 of 16 (permalink) Old Jun 30th, 18, 03:37 PM Thread Starter
keith
X-77 keith's Avatar
That gasket and or waterneck one or the other fixed my problem. No more dribble. 👍
X-77 keith
post #13 of 16 (permalink) Old Jun 30th, 18, 03:56 PM
Daryl
1968RallySport's Avatar
Re: Thermostat drip
Everett is correct. Glass is a amorphous solid. Look at a historic home with original glass. Youíll see what Everett is talking about.
1968 Rally Sport
302ci
Muncie M22
Moser 12-bolt 4:10 posi
1968RallySport is offline
post #14 of 16 (permalink) Old Jun 30th, 18, 05:37 PM Thread Starter
keith
X-77 keith's Avatar
I heard many years ago that glass was in a constant state if movement. Totally forgot about that.
X-77 keith
post #15 of 16 (permalink) Old Jul 1st, 18, 06:37 PM
Morgan
Re: Thermostat drip
I file the cover flat and use the permatex for thermostats, it is silver and blends right in on alluminum intakes. I use no gasket and a light coat on each side, just barely snug the bolts by hand, enough to see the first sign of compressing the permatex, wait 60 minutes and snug down with the wrench, the sealer is what seals, not the torque of the bolt, I have never had one leak using this method
69 Copo 9560 ZL-1 automatic [email protected], 1.95 on f70-14 polyglas F.AS.T. Race June 2016
69 Copo 9560 ZL-1 4spd [email protected] 1.93 60ft on F70/14
PSMCDR 2014
71LS6 vette [email protected] PSMCDR 2012 SOLD
1971ls6 is offline
