Vintage air in a non factory A/C 1969 Camaro - Page 2 - Team Camaro Tech
Heating & Cooling Heating, cooling and air conditioning Sponsored by:Cold-Case Aluminum Radiators
 6Likes
post #16 of 17 (permalink) Old Jul 3rd, 18, 12:36 PM Thread Starter
Shad
zboss86's Avatar
Re: Vintage air in a non factory A/C 1969 Camaro
Originally Posted by X-77 keith View Post
I put mine right in the pad with clips. The pad actually had dimples for the holes. I used a OER pad and a OER. Vent.
Originally Posted by Vega$69 View Post
Thatís the way they work. 👍
Ok, I caught on a little late to that... I didn't even realize that's the way it worked until I saw that pic from the manual yesterday morning. There's a metal flange from the factory that the center vent just happens to be able bolt right up to 2.25" back from where it's suppose to sit. It threw me for a loop.
I just need to find those clips and I'll be set.
thanks guys...
My Mistress rebuild...
zboss86 is offline
post #17 of 17 (permalink) Old Jul 4th, 18, 06:55 AM
Beth
Hey Shad,
I'm right in the middle of installing a gen IV VA system in my non-air 68.
I read guys complaining about fitting the #10 suction hose under the dash ; I had no idea what they were complaining about until last night.
I installed the evaporator under the dash and that hose has to make a sharp downward bend into the kick panel opening. Vegas has recommended using a reduced barrier hose and loop it under the dash to relieve the stress from the line.
I think mine's ok; it doesn't seem to be under a whole lot of stress although I wouldn't say it's "stress-free."
This doesn't apply if you are running your hoses out of the area where the heater hoses used to be. Just thought I would mention it.
zboss86 likes this.
NashvilleCat is offline
