New A/C compressor, how much oil? - Team Camaro Tech
 2Likes
  • 1 Post By Johnny B
  • 1 Post By 1968RallySport
post #1 of 7 (permalink) Old Jul 14th, 18, 02:28 PM Thread Starter
I have a 68 Camaro with factory A/C. Iíve flushed/pressure tested the condenser coil, POA valve, new expansion valve and compressor and flushed the rest of the system. I assume there is like to no oil in the system especially once I vacuum it down. The service manual says it takes 11 oz of 525 mineral oil. I drained out the oil that was in the new compressor because Iím not sure itís not PAG instead of mineral. I only got 2oz from it. Oh yea Iím going back with R12 because I have it. 11 oz seems like a lot. Does this seem like the right amount seeing as I purged the system? I donít want to over service it.
mferris72 is offline
post #2 of 7 (permalink) Old Jul 14th, 18, 04:57 PM
Beth
Re: New A/C compressor, how much oil?
I would talk to these people :
https://www.classicautoair.com/original-air-group/
NashvilleCat is offline
post #3 of 7 (permalink) Old Jul 14th, 18, 11:12 PM
The oil amounts should be the same for 68 or 69. I don't see why they would be different. Here are the specs for a 69.
You add a total of 11oz 525 viscosity mineral based oil for R12:
From a dry system add:
3 oz to the Evaporator
1 oz to the Condenser
1 oz to the Receiver Drier
6 oz to the Compressor.
Sounds like a lot of oil to me too. But this is what the 1969 Chassis Service Manual says. I've used that much without any trouble. Can you use less? I don't know....Jb
1968RallySport likes this.
Beat it to Fit, Paint it to Match!
Johnny B is offline
post #4 of 7 (permalink) Old Jul 15th, 18, 09:13 AM Thread Starter
Yes 68 and 69 are the same. My service manual has the same info. I guess my concern is that there might still be some still in the system even though I flushed the system. Iím going to go with the 11 oz. and hope for the best. Thanks for your input!
post #5 of 7 (permalink) Old Jul 15th, 18, 12:26 PM
Daryl
1968RallySport's Avatar
11 oz. sounds like a lot because the A6 compressor has a reservoir (sump). Modern air compressors do not. They rely solely on the oil suspended in the refrigeratant for lubrication.
dhutton likes this.
1968 Rally Sport
302ci
Muncie M22
Moser 12-bolt 4:10 posi
1968RallySport is offline
post #6 of 7 (permalink) Old Jul 15th, 18, 01:36 PM Thread Starter
That makes sense, they are physically bigger them the newer types.
post #7 of 7 (permalink) Old Jul 16th, 18, 09:40 PM
Remember, not all the system's refrigerant oil is held in the compressor. Some remains in each component, coats lines, coils, ect. Thus, only replacing the amount that is drained out of the old compressor or accumulator or condenser, whatever. The amounts above are just a starting point when filling a new or flushed empty system. The Happy levels for oil accumulation are close to these amounts. And yes, the refrigerant is the vehicle for distributing the oil everywhere.
Johnny B is offline
